Interior on 91 Z-28 with wood
Old Sep 1, 2017 | 12:46 PM
tdmason's Avatar
Yes, I just bought this car and am going to redo it slowly (project car) question... the slider is broke. So I want to replace it. Is this wooden look something aftermarket? All i can find are the plain black ones and they only seem to sell the whole center instead of just the slider. Is that right? This is a Z-28 Im assuming what they call a G-92 version??? Does the wood just screw off of this and onto another? I cant really tell if factory or not just looking at it. Any help greatly appreciated. Thanks
Old Sep 1, 2017 | 12:56 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: Interior on 91 Z-28 with wood
Wow, now that's a first to me. I have seen simulated woodgrain on 80s era Grand Prixs and some Buicks but I can assure you it didn't come on Camaros.
Old Sep 1, 2017 | 04:35 PM
TOM305T/A's Avatar
Car: 1987 GTA 350 auto
i have seen 3rd gen trans am with wood grain. but never a camaro
Old Sep 1, 2017 | 06:03 PM
Drew's Avatar
It's aftermarket. They used to sell those peel and stick wood grain kits in the JCWhitney catalog. Classic Industries even had them in the 90's.
Old Sep 1, 2017 | 06:08 PM
Drew's Avatar
I guess they still do.
https://www.classicindustries.com/pr...rts/1014w.html
Old Sep 1, 2017 | 07:36 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
And you should be able to replace the slider.Be easier than removing/re-appyling that woodgrain.
Old Sep 2, 2017 | 05:22 PM
tdmason's Avatar
The places online I looked at only sell the whole piece and not just the slider. I thought that was strange and a waste
Old Sep 2, 2017 | 05:27 PM
tdmason's Avatar
Originally Posted by Drew
Even looking at the ones i see online, I cant find the same pattern as the one in this car
Old Sep 2, 2017 | 05:56 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
You will have to buy a complete used shift plate and cut both yours and the new used one apart to put a new slide in. The units are glued together and no one sells just the slider part.
Old Sep 2, 2017 | 06:02 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
A busted one with a good slider to fix yours.Ive fixed one this way before, still easier than trying to re-apply the laminate.
Old Sep 2, 2017 | 06:38 PM
Drew's Avatar
The kit in your car would be called Burl wood. The wood kits never caught on really, and if you notice Classic's listings for the two types they have are on closeout. Finding a burl wood kit now probably isn't easy, but 15 years ago they were as close as the parts catalog.
If you like it, or tolerate it, I'd leave it alone. There's a chance a person could lightly heat it with a hair dryer to soften the adhesive, and peel them off. But there's also a chance the stickum is permanently stuck, and trying to remove it might cause more damage.
Old Sep 2, 2017 | 09:10 PM
my82roc's Avatar
Car: 89 Iroc Convertible
I have a bunch of those ribbed slider pieces if your interested
Old Sep 2, 2017 | 10:49 PM
tdmason's Avatar
Definitely!!!
Old Sep 3, 2017 | 11:50 AM
my82roc's Avatar
I'll sell the ribbed slider piece for 20 dollars shipped
