PARKING BRAKE LEVER
Old Jan 9, 2018 | 03:47 PM
gt4373's Avatar
Transmission: 5-Speed Manual
PARKING BRAKE LEVER
Is The Rubber Filler That Goes Around The Parking Brake Lever Replaceable,Do Any After Market Companies Even Make Them.
Old Jan 10, 2018 | 11:49 AM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: PARKING BRAKE LEVER
I'd be surprised if anyone made this part by itself. More than likely you'll have to replace the entire console assembly, or you can try to find someone with a good one that they'll sell you.
Post back if you find a source though, my '02 needs one BAD.
Old Jan 17, 2018 | 03:45 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I'll look at the underside of one of my consoles when I get home, I think that its just sandwiched in place and any piece of thicker rubber would work.
Old Jan 18, 2018 | 09:14 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
It appears that the Chevy(Rubber) has a different style than the Pontiac(Bristles).Maybe you can pull the console and glue a solid piece of rubber across the opening and just put a slit down the middle.Just a thought!!.
Old Jan 18, 2018 | 10:34 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
You can easily just glue in a new piece of rubber. Mine is shot too and that's what I'm going to do.
firebirdjosh
Apr 21, 2008 11:07 PM
Blkdth87
Brakes
Apr 8, 2005 06:40 AM
sellmanb
Dec 18, 2004 03:46 AM
rnyost
Oct 29, 2003 07:17 PM
camarosource
Jul 3, 2003 11:57 PM
