89 GTA Rear parking brake lever
Car: 1989 Flame Red GTA 5spd, 89 Bright
Engine: 305tpi and 350tpi
Transmission: Auto and 5spd
Does anyone know where I could find or does anyone have a rear parking brake lever for an 89 GTA 305/5spd rear disc J65 axle (australian). GM part # 10132834. GM has discontinued this part. I also need 2-push rods and 2-lever return springs. It will also work of a 350tpi as I also have one as long as it's the J65 axle. I believe it will only work out of an 89-92 with the J65 axle. Most 88's and back aren't the same and GM carries those parts.
Robin Yost
tryost@hotmail.com
Robin Yost
tryost@hotmail.com
Blown up illust. of caliper and lever
Are you sure they are the same? Does the parking lever/actuator/arm look the same as this picture? I'm at my wits end with this. Wouldn't the parts manager at GM know that and maybe suggest purchasing the parts from a newer Fbody?
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
You'll be VERY hard pressed to find those parts all by themselves. You're best bet will be to but a whole set of calipers just to get these parts, but then you'll have extra stuff.
Ed
Ed
'93-97 actually, just to be **** about it, but yes. Everything except the e-brake cables, those will have to be for a 3rd gen.
Ed
Ed
Sorry 1 more thing about the 4th gen rear brakes. I seen the caliper do look the same but what up with that big circle thing the only pic i see is kinda far away. Does that have something to do with the ABS or will they still bolt up n work with third gen cables. Thanx alot
I have those big round things on my calipers in the shop. I hear they're for reducing vibrations or something like that, but they serve no purpose and do nothing. You can remove them if youd like.
Ed
Ed
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
