Trunk Flooding-1984 Trans Am
Old Jan 21, 2018 | 05:56 PM
my1st66mustang's Avatar
I've recently been working on restoring a car that had been sitting around for awhile and have come across this issue where the trunk begins to flood when it starts raining, I don't have much to say beyond that but I do have pictures of the trunk and where I think it is coming from.
Old Jan 21, 2018 | 06:29 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Trunk Flooding-1984 Trans Am
That looks like it's coming from the seam that seals the rear glass to the rear panel.Your sealant might be dried up.
Old Jan 21, 2018 | 06:57 PM
Ok, i'll see if thats the problem, I'm going to try to pull the panel and trunk strut off to look into it further, thanks for the advice.
Old Jan 21, 2018 | 09:19 PM
Drew's Avatar
Knock the body plug out of the storage well and let that water drain.
Check around the flat black plastic filler pieces that span the gap between the glass and decklid. The plastic filler is supposed to be sealed to both parts with the gap filled.
There's also a ton of seam sealer where the 1/4 panels meet the tail panel. You'll see the seam just above the tail lights on either side. The bulk of the seam is behind the tail lights. If the sealer is dried and cracked, the rain water will just run down the gap and enter the trunk.
Old Jan 22, 2018 | 12:59 AM
Well I think I've narrowed it down to a passenger side area issue as when the panel was piled ofc this is what I got. Passenger side
Weatherstripping possibly indented?
Driver side, rust stops about midway.
yusky03
Sep 6, 2012 10:17 PM
cxxm
Mar 25, 2012 02:09 PM
jimp2001
Feb 19, 2006 12:56 AM
90vertcamaro
Car Audio
May 10, 2004 09:44 PM
