ACC rear carpet
Old Aug 26, 2018 | 05:29 PM
johnw999's Avatar
ACC rear carpet
For those that have installed ACC carpet, does the rear section need any trimming? Like the front carpet, my rear carpet looks like it needs trimming around the edges. Right now, it’s getting the brick paver treatment. It’s amazing how much more manageable the carpet is after a day or 2 in a hot Texas garage with 75+ lbs of pavers pushing down. The areas that wouldn’t lay flat are now properly molded.
Old Aug 29, 2018 | 05:22 AM
alicat's Avatar
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
Re: ACC rear carpet
The rear carpet that I have recently fitted in my 85 camaro was too wide, as it came. I measured off my old carpet, and all the excess seemed to be on the right hand side.
When I had trimmed the new piece, I found that I had trimmed too much on the right, just where it comes off the fuel tank area to go down behind the seats. Luckily it was only a small piece, and I was able to glue a piece in, which is hidden by my amp deck.
I would suggest, that if you still have the old rear section in, then mark where the edges come to at a few points on both sides, then when you lay the new piece, make sure that the well area, is in place correctly, then see how much overhang you have, where your marks are, If you have to trim before it will sit reasonably flat, only trim small amounts at a time. easy to cut off, not so easy to fix.
The only other Issue that I had, was in the well area, on the right corner, Where I had to remove some of the jute padding, to get it to sit properly.. This is with the mass backing.
It would be nice if ACC made the carpet with all the excess on one side, but obviously there is excess on both sides.
Hope this helps.
Cheers,
Alicat.
Old Aug 30, 2018 | 10:16 AM
johnw999's Avatar
Re: ACC rear carpet
Thanks. I wish I hadn’t thrown away my old carpet. I can see the molding lines on the mass backing, and that gives me an idea of where to cut. Also, I found a used rear carpet on eBay. The pictures also helps me decide where to cut.
Old Nov 9, 2024 | 05:40 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: ACC rear carpet
I didn't have to cat anything forward of the console just at the doors,did you buy the one with the console alread cut for you?
Old Nov 9, 2024 | 06:45 PM
johnw999's Avatar
Re: ACC rear carpet
The carpet was an uncooperative amoeba. That was 6 years ago. I eventually figured out how to mold it. This was my process
https://www.thirdgen.org/forums/inte...sole-hole.html
87WS6
Aftermarket Product Review
68
Jan 29, 2026 12:46 PM
battmann
Nov 9, 2024 01:10 PM
sr20fd3st
Dec 2, 2009 07:07 AM
Aaron_SK
Feb 26, 2009 12:05 AM
gscz28
Aug 28, 2006 12:19 PM
