1987 Z-28 Cold To Hot Lever Stuck On Cold
Old Oct 22, 2018 | 03:51 PM
RTJ49's Avatar
My 87 Z-28 has the lever for cold to hot on the center console/dash stuck in the cold position. Any ideas on getting this to work? It is getting cold.
Thanks,
RTJ49
Old Oct 23, 2018 | 01:22 PM
Abubaca's Avatar
Re: 1987 Z-28 Cold To Hot Lever Stuck On Cold
Is the lever physically stuck, or does it move, but not actually change the mode? If it's physically stuck, I don't think there's any actual procedure other than to get in there and see what's not working. It's pretty easy to remove the HVAC unit and poke around. ....if it's moving, but not changing the mode, you may have a vacuum line disconnected somewhere. I think the hot/cold was vacuum actuated.
Old Oct 27, 2018 | 05:16 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
There's a small valve but it's mainly cable operated . Cable likely stuck
malcontents
Nov 23, 2015 07:35 PM
Austin19
Apr 25, 2014 02:00 AM
babyelephant
Interior Parts Wanted
Sep 18, 2013 01:27 PM
SpeedRacerX
Dec 16, 2010 01:24 PM
bigjeepinyj
Oct 14, 2002 02:51 PM
