RPO label question
Old Feb 28, 2019 | 04:27 PM
fastsspr's Avatar
Car: 1985 Yellow Iroc Z w/LS interiors
Engine: 305ci 5.0L
RPO label question
Hello guys after a long time of bean not a owner of a third gen. I'm back , yesterday a bought the 85 TPI with near perfect interior with 123k miles.
Have the interiors of my first Iroc back in 1987. Now the sad part is the RPO label is missing. Is possible to find a copy a RPO label with the VIN number?
Old Feb 28, 2019 | 04:34 PM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Re: RPO label question
Tag for info. My Trans Am RPO label is there, just nearly completely illegible.
Old Feb 28, 2019 | 05:59 PM
Saxondale's Avatar
Car: 84 Z
You may have a build sheet on the underside of the passenger bucket. If there then remove the seat to extract it from behind the seat support wiring.
Otherwise you can order a dealer invoice from GM for $50. But it will have less detail than the build sheet.
Old Feb 28, 2019 | 08:03 PM
fastsspr's Avatar
Engine: 305ci 5.0L
Man as soon I saw your advice I went and pull out the seat and was no build sheet under it 😞.
Old Feb 28, 2019 | 08:12 PM
fastsspr's Avatar
Engine: 305ci 5.0L
Any other spot that built sheet can be?
Old Feb 28, 2019 | 09:26 PM
Saxondale's Avatar
Car: 84 Z
All of the build sheets I have found have been beneath passenger seats of Van Nuys Camaros built for approximately the 1984 model year. In the upper midwest the majority of our cars were built in Van Nuys. Others have found sheets throughout their cars. But maybe after 84 it was less common.
Old Feb 28, 2019 | 09:53 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Build Sheets Are Hit And Miss,They Weren't Required To Be Left In The Car Your Car May Not Even Have One.
Old Mar 1, 2019 | 12:49 AM
J.C. Denton's Avatar
Car: 85 Iron Duke, 88 GTA and 92 TA
In my 92 TA the build sheet was hidden under the passengers door panel, but I have the SPID in the rear storage box. Also in my long gone black 92 V6 it was at the same spot. In my 88 GTA I wasn't able to find the build sheet and it is also missing the SPID. But I never looked under the seat, I always thought they hide it just under the door panel. I have the dealer invoice so I know it is a real GTA, but as stated above, it shows only a few things and not everything. Will have a look under the seat next week.
Old Mar 1, 2019 | 05:45 AM
Saxondale's Avatar
Car: 84 Z
With the VIN, dealer invoice, and radiator support body tag you can confirm a lot of information specific to an ‘85, including month and week of build.
Old Mar 1, 2019 | 07:52 AM
sshoureas's Avatar
The build sheet in my 1987 IROC was under the drivers side bucket seat. Did you look there? Mine was Van Nuys built also.
Old Mar 1, 2019 | 11:27 AM
fastsspr's Avatar
Engine: 305ci 5.0L
I
​​​​​​I will going to check under the seats and both door panels. At the same time is a good opportunity for a good clean up. This are the labels in the driver side door.
Old Mar 3, 2019 | 07:00 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
What year did they start putting the RPO sticker in the back storage pods?
Old Mar 3, 2019 | 07:08 PM
BizJetTech's Avatar
IMO, it was 1991 or 1992
Old Mar 4, 2019 | 11:53 AM
fastsspr's Avatar
Engine: 305ci 5.0L
I went to the back storage, spare tire cover,under the hood, console lid, definitely that label is missing. I pull out all the seats and door panels, to see if can find a build sheet with no luck.
I will going to end buying a invoice copy to have more info. about this car.
Old Mar 4, 2019 | 12:20 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Try under the passenger seat CARPET.
Old Mar 4, 2019 | 04:23 PM
fastsspr's Avatar
Engine: 305ci 5.0L
Hmmm i will do it. Thanks
amfornal
Aftermarket Product Review
27
Aug 11, 2019 06:14 PM
BlackBird20
May 4, 2006 03:28 PM
Bralgar
May 18, 2002 11:24 AM
MikeInAZ
Apr 27, 2002 12:57 AM
MikeInAZ
Apr 15, 2002 09:26 PM
