Need Help with Hatch
Old Mar 14, 2019 | 02:06 PM
1987Mike's Avatar
Car: 1987 Camaro
Engine: LQ9 - LS3 Heads
Axle/Gears: Ford 9" - 3.90 gears
I recently purchased the Hawks rear hatch motor, the complete thing. Someone had removed ALL of the hatch motor from the car before me, so I had only the lock cylinder not connected to anything. I don't have any switches up front either, so the only way to pop the hatch is to insert a screwdriver into the latch and pop it up.
How does the lock cylinder connect to the hatch motor so when you turn the key behind the plate, the hatch opens?
This is a 1987 car if that helps any.. .
Where does the white wire connect to?
Rust in the pan here is next on my list.
Old Mar 14, 2019 | 09:29 PM
3rdgenzroc's Avatar
Car: 86 Iroc-Z
Engine: 383 HSR
Re: Need Help with Hatch
This video should help: https://video.search.yahoo.com/searc...5&action=click
  • Also you should have the release with it.
Old Mar 14, 2019 | 09:31 PM
3rdgenzroc's Avatar
Car: 86 Iroc-Z
Engine: 383 HSR
Here is the schematic:
Old Mar 14, 2019 | 10:46 PM
1987Mike's Avatar
Car: 1987 Camaro
Thank you so much! Found and ordered the part.
TX-SleeperC5
Interior Parts Wanted
Oct 1, 2014 12:54 PM
LT1IROC-Z
Jan 6, 2013 04:40 PM
chuck6860
Jul 23, 2002 09:36 AM
