Pedal Customization
Old Apr 27, 2019 | 11:38 AM
JonJon5.0's Avatar
Pedal Customization
Old Apr 27, 2019 | 11:39 AM
JonJon5.0's Avatar
Re: Pedal Customization
Anybody know where I can find pedal covers like these or if it’s other pedals that are interchangeable with 3rd gens similar to these ?
Old Apr 27, 2019 | 12:18 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Doubt theres anything interchangeable and those cheesy covers are, well cheesy to say the least.I have Chrysler crossfire pedals in mine, but they are not a drop in part.
Old Apr 27, 2019 | 12:24 PM
JonJon5.0's Avatar
How did you install it
Old Apr 27, 2019 | 12:53 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I had to modify the pedal base.
Old Apr 27, 2019 | 05:39 PM
JonJon5.0's Avatar
I’ll probably just end up painting mine to look better seems options are very limited lol
Old Apr 27, 2019 | 08:46 PM
NoEmissions84TA's Avatar
Old Apr 28, 2019 | 12:21 AM
Drew's Avatar
I think these "Racing" pedals might be somewhere in the bottom of a junk barrel. Was saving them for a white elephant gag gift.
All kidding aside, even most of the fancy covers are just for decoration. The stock grippy rubber will usually work better in all elements than billet aluminum or stainless steel. If a person was really serious, they could cut the pedal pads to fit covers from another car, or cut the pads off a donor car with covers you like better, and weld them onto the stock pedal arms. Most of the time the end result looks just as corny as Walmart pedals covered in mud and a floor littered with garbage, but follow your heart.
Old Apr 28, 2019 | 12:17 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
The clutch and brake arms and pedals in my brothers Corvette Z06 are all aluminum. Light weight compared to their steel counterparts in a std. Vette I guess. But they would not be drop in, nor cheap.
You can probably look at a a racing supplier site and find something, but again, it won't be a drop-in conversion.
Old Apr 28, 2019 | 01:45 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I tried the vette aluminum brk pedal years ago.I remember the bend/angle put the pad too close to the gas pedal or maybe it was the other way around.Also the plate for the brake light switch was in the wrong spot.Was a nice piece though....My crossfire pedals.
Old Apr 28, 2019 | 08:41 PM
ThePain's Avatar
Car: 1992 RS
Transmission: Automatic
Digging the 2din and shifter mod!
Now you just need a white fog light button
Old Apr 28, 2019 | 10:36 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Thank you, that switch is for the trunk release.Since the verts have the tonneau switch on the console.I wired that in cause its convenient having it there.I do need it in white though.
IrocUBabe
Apr 30, 2003 08:45 AM
1989TransAm
Car Audio
Dec 8, 2002 10:14 PM
82Tankmaro
Oct 3, 2002 10:49 AM
Kj Rockz
Feb 24, 2002 11:09 AM
86FyrBrd
Jan 13, 2001 06:04 PM
