Anyone tried to polish the instrument cluster clear plastic?
Old Feb 21, 2019 | 03:35 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
I have half of a 3M headlight restoration kit sitting there along with evil thoughts. Kit works great on plastic headlamps. Really polishes the plastic up. My cluster is a little foggyish.
Old Feb 21, 2019 | 03:37 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Re: Anyone tried to polish the instrument cluster clear plastic?
Done it many times. Well worth the effort! Best way is to remove the lens and do it off the car.
Old Feb 21, 2019 | 04:39 PM
82tarecaro's Avatar
I have had luck with plastx in the past on light scratches
Old Feb 21, 2019 | 05:35 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Old Feb 22, 2019 | 08:50 AM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
PlastX here too. Worked very well, as seen in the link below.
https://www.thirdgen.org/forums/memb...ml#post5911259
Makes it feel like a new car, looking down at the gauges through those crystal clear lenses.
Old Feb 22, 2019 | 09:30 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Yup, have done several.
Old Feb 22, 2019 | 11:15 AM
88IROCvertZ's Avatar
Car: 1988 IROC Z Convertible
Engine: 305 TPI (LB9)
Transmission: 700 R4
Axle/Gears: G80 GU2
These guys are right.. most people don’t know how to properly clean clear plastic including convertible and Jeep windows.. It’s not glass so cleaning it wrong will scratch it and make it hazy..
Old Feb 22, 2019 | 11:38 AM
chazman's Avatar
Axle/Gears: BW 3.45
I've used PlastX on hazy convertible rear windows, too.
Old Feb 24, 2019 | 09:18 AM
Abubaca's Avatar
PlastX here too. ......I use a drill press and a polishing buff from Northern tool...or wherever you prefer. Doing tails here, but same idea.
Old Feb 24, 2019 | 09:56 AM
Axle/Gears: G80 GU2
PlastX is good stuff.. did wonders on my convertible window..
Old Feb 24, 2019 | 10:01 AM
chazman's Avatar
Axle/Gears: BW 3.45
Using PlastX is part of my routine whenever I get a "new" car. IP lenses, convertible top windows, tail lights, turn signal lamps, etc. It's all the little things. You put all those little things together and you get a much nicer presentation.
Old Feb 24, 2019 | 10:24 AM
Axle/Gears: G80 GU2
absolutely and even newer cars.. I’ll do my Tahoe lenses a couple times/year and they still look new.. I know people with 4 year old cars starting to get hazy headlights..
I need to hit more spots on my IROC with it..
Old Feb 24, 2019 | 10:35 AM
BizJetTech's Avatar
Here is a product that is popular in the Aviation industry and works excellent.....
http://micro-surface.com/index.php/p...-industry.html
Old Mar 7, 2019 | 11:16 AM
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
For more noticeable scratches I've done wet sand sequence and VS polish with excellent results. Be careful with the cluster plastic, it is really fragile, and can crack for no apparent reason....
Old Mar 7, 2019 | 11:49 AM
yevgenievich's Avatar
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
using headlight polishing kit worked fine to fix the sanded/painted cluster plastic(previous owner blacked out fuel gauge for some reason) on my 79 c10
Old Mar 7, 2019 | 12:22 PM
Ct1987's Avatar
Hello,
I fly a helicopter for a large company and we go into many un-prepared areas that are very dirty.
For years, I have used toothpaste to get rid of small scratches from the wind screen. Older brands work best, such as Pepsodent.
Wash plastic throughly, dry with a soft flannel cloth and apply toothpaste with a wet piece of cheesecloth. Let dry and buff with another clean piece of cheesecloth.
Louis
Old Mar 27, 2019 | 01:26 AM
Guest
Guest
Posts: n/a
NOVUS plastic polish is the only way to go. It will make lenses and other items like new.
Old Apr 22, 2019 | 11:24 AM
Engine: 350 TPI L98
Transmission: WC T5
Used 3M Headlight polish by hand. Worked great.
Old Apr 28, 2019 | 08:39 PM
ThePain's Avatar
Car: 1992 RS
Transmission: Automatic
Anyone have suggestions for wiping the cluster clean of dust without scratching it? Or is the trick just to use some PlastX while you clean it?
Old Apr 28, 2019 | 10:53 PM
427seven's Avatar
soft damp cloth.... if it's greasy start with the cloth a bit wetter from an ice cream bucket filled with warm water, one drop of dishwashing detergent in it....
Elmars Romeiko
Interior Parts Wanted
Dec 5, 2017 07:05 PM
Chuck84TA
Jan 30, 2013 12:29 PM
v8_musclehead
Mar 31, 2008 11:02 PM
laydebug
Jun 2, 2007 05:24 AM
redbird_400
Sep 9, 2002 01:52 PM
