I have a idea for door panels
Re: I have a idea for door panels
the big issue with door panels in thirdgens is there's not a lot of room between the door panel and side of the seat / your legs. a lot of modern door panels are build-out and have recesses for cup holders, handles, speakers, etc... you really only have room to do that in the front half of the door panel in thirdgens. the back half of the door panel kind of needs to stay flat like stock.
It might take a lil bit of trimming here and there but man it would look sooo good in a 3rd gen
the trimming has to look professionally done so it won’t look out of place or jacked up
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Trimming? That door panel is flat out the wrong shape and length. No amount of trimming is going to make that work. I think you could potentially make a set of 3rd gen panels have that look if you make all the raised parts out of fiberglass and then transfer the shiny bits over.
86FyrBrd
02-09-2014 09:58 AM
CARHARTTKOWBOY
Interior Parts Wanted
09-21-2012 09:36 AM
subroc
07-11-2009 05:43 PM
bad84z
05-24-2003 05:18 PM
