A/C Box Door Insulation
Old Aug 28, 2019 | 11:33 AM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Does anyone know where I can get the thin foam like material that insulates the airflow doors that are inside the A/C and heater core box? You know, the replacement for the fuzzy crap that shoots out of the vents on our old cars. 😜 Also any idea where to get the green foam material that acts as a gasket on various parts of the box?
Old May 20, 2020 | 04:38 PM
ken23434's Avatar
Car: 1986 Z-28
Engine: LB9
Re: A/C Box Door Insulation
Did you ever get an answer?
My doors are bare steel w surface rust. I assume there used to be something on then. Found your post by accident/search.
Old May 20, 2020 | 06:36 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
I ordered some 1/16th inch closed cell foam off of the net. Don’t recall where but I soda blasted parts and applied spray on adhesive to door flaps cut to size. Let them dry overnight and reassembled. Worked great. Take pics of flaps before cleaning so you can cut pieces correctly.
Old May 20, 2020 | 06:41 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Check out post #175-177 on my build post. https://www.thirdgen.org/forums/ltx-...ld-thread.html
Old May 20, 2020 | 07:12 PM
ken23434's Avatar
Car: 1986 Z-28
Engine: LB9
Thanks, BADMAN. That should help a lot when I reassemble. Mine are so far gone, not only can I not tell where material was I had no idea what type of material it was.
​​is that foam on both sides of all the moveable doors? Us there any inside the main box itself?
Thanks again.
Old May 20, 2020 | 07:37 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Thanks again.
Material is on both side of doors. None inside box. Don't have pics of both sides of flaps. Maybe ask on TGO Heating and Cooling thread and see if someone has pics or a diagram. I just copied what was on there before I blasted old material off. BTW that was 3/16th closed cell foam, not 1/16th.
Old May 21, 2020 | 12:34 AM
gscroll's Avatar
Car: 91 Z28
Engine: L98 5.7L 350 TPI
Transmission: It works.
Any fabric store like Joann's would have foam in stock. They come in rolls and usually in green or white.
Old May 21, 2020 | 10:54 AM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Need to make sure it is closed cell foam. Regular foam sheeting will not last.
Old May 21, 2020 | 11:29 AM
gscroll's Avatar
Car: 91 Z28
This This
might do it.
Old May 21, 2020 | 12:20 PM
ken23434's Avatar
Car: 1986 Z-28
Engine: LB9
Thanks for the help. Like the add on Amazon. I can buy a gun case to get the foam... 2 different needs in one purchase.
Old May 21, 2020 | 01:53 PM
gscroll's Avatar
Car: 91 Z28
Nice.
BADMAN
Aug 28, 2019 08:15 PM
Streetrod4
Interior Parts Wanted
Oct 18, 2018 09:52 AM
Streetrod4
Exterior Parts Wanted
Oct 15, 2018 08:47 PM
babyelephant
Sep 18, 2013 01:27 PM
86Z
Jan 12, 2009 06:32 PM
