Is a tilt/non-tilt steering column interchangeable?
Old Dec 11, 2019 | 04:02 PM
MichelleP's Avatar
Car: 85 Pont Firebird TransAm
Engine: 305 V8
I'm renovating my 85 TransAm and had to pull the column because a part broke inside. I couldn't get the sleeve off without destroying it. I'm thinking I need to buy a new column. I found one nearby but it is non-tilt and mine was a tilt. Does that matter? Could I use it for the interim and then replace with a tilt? Any help is much appreciated as I'm new to this (but loving every minute).
Old Dec 11, 2019 | 05:22 PM
91ls1t56's Avatar
Car: 91 Z28
Axle/Gears: Moser 9" 3.70 35 spline wavetrack
Re: Is a tilt/non-tilt steering column interchangeable?
It will bolt in the same. It may not be an exact match for wiring such as wiper controls, cruise, and radio. The plugs should be the same with less or more wires in them.
Old Dec 11, 2019 | 07:45 PM
BIRD91ZRAG's Avatar
Where are you located? If you're near northeast Indiana I can help you out.
Old Dec 11, 2019 | 09:24 PM
MichelleP's Avatar
Engine: 305 V8
I would so take you up on that but I live in the Phoenix area.
mik-hey
Jul 25, 2009 04:01 AM
ops32
Aug 19, 2004 01:33 PM
dei305ta
Feb 10, 2003 12:42 PM
89RsPower!
Jun 16, 2002 01:21 PM
bzznczzn
Nov 20, 2001 01:01 PM
