(Need help) Temp fix for broken power seats? ('84 Camaro)
Old 01-02-2020, 01:53 AM
IneptusMechanic's Avatar
Hey folks, very-soon-to-be new owner of an '84 camaro here. I've already found the fix for the broken upper belt retractor, but my main issue is that the powered driver's seat is broken - none of the functions work. I'm picking the car up tomorrow, and the seat is stuck all the way back as far as it will go. So far, I know to check the (circuit breaker? fuse?) that runs the power locks, seats, and rear defroster, but I'm wondering if there's a way to manually adjust the seat. Something like a bolt on the seat's motor shaft, which is what my other car has. If that doesn't work I'm thinking of just unplugging the seat, running power to the plug via a battery or something, and trying that. If anyone has any knowledge or suggestions to share, that'd be great.
Old 01-02-2020, 08:53 AM
Lakerman62's Avatar
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
Re: (Need help) Temp fix for broken power seats? ('84 Camaro)
Once I swapped out to a manual seat bottom rail and haven't looked back......
Old 01-02-2020, 10:57 AM
GeneralDisorder's Avatar
The seat is entirely self-contained. Just find the electrical plug under the seat and give it power and ground and if the motors are good it should work. I added a power seat from a 2001 Firebird to my 86 and only had to wire in 12v acc. power to it.
GD
Stu's '85 IROC
07-01-2012 07:06 AM
breesmom
01-19-2004 12:43 PM
91RS5speed
08-09-2003 04:44 PM
89RSProject
03-28-2001 01:07 PM
Wolfcoast
12-20-2000 05:13 PM
Quick Reply: (Need help) Temp fix for broken power seats? ('84 Camaro)
