Possibility of Power Windows?
Old Jan 9, 2020 | 06:49 PM
McCall's Avatar
Car: 1983 Camaro Z/28
Engine: 350 Bored to 355
My 83' Z28 has the original crank windows, is there a possibility of power windows?
Old Jan 9, 2020 | 06:56 PM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Re: Possibility of Power Windows?
Probably. The power windows in these cars tend to be crappy at best and completely suck at worst. I wish my TA was manual windows TBH.
Old Jan 10, 2020 | 09:27 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
You can either build your own power window harness, or pull one out of another car and add it, but either way it is a lot of work. You need to change the window regulators in the doors too.
I upgraded the harness in my 92 Firebird and ran 10 or 12 gauge wire from the window closing module to the motors and ran the same for power to the module. I also cleaned and lubed up the tracks well and now the windows open and close better than new.
Old Jan 10, 2020 | 01:57 PM
Drew's Avatar
It's an easy conversion really, once you have the parts. The biggest headaches are dealing with the holes in the door panels leftover from the cranks, or vice versa the holes left in the console from the window switches.
Old Jan 30, 2020 | 06:41 PM
Jimmy alphin's Avatar
Car: 92 Z28/ 72Pro Street Monte Carlo
Engine: 305tpi soon to be 383/ MC has 454
Transmission: 700r4 / TH400
Axle/Gears: 3.42 / 4.44
I have complete harness removed from 92rs. It was a pain to remove. Had to remove entire dash as it runs just under windshield below dash frame. Took 3 hrs to remove. Could possibly be routed differently as to not remove dash. Decided to sell my 91 non power rs. Bought a loaded 92 Z.
jayonemo
Jun 7, 2014 06:41 AM
camaro8811
Apr 16, 2008 05:31 AM
adam86
Jan 1, 2007 09:37 PM
