Replace power windows with power windows
Old May 25, 2014 | 12:38 PM
jayonemo's Avatar
Engine: 355
Transmission: 350
Axle/Gears: 342
I saw some after market power window kits online. Can I replace my slow power windows with one of these kits
Old May 29, 2014 | 08:05 PM
zero13's Avatar
Car: 91 Z28
Engine: Enhanced 5.0L
Axle/Gears: 3:42 Posi
Re: Replace power windows with power windows
you dont need a kit..you just need new window motors..unless you are using underpulleys,you should replace both window motors..there is a thread here how to do it..I have done it and now my windows go up n down at same speed,and not slow....
Old May 29, 2014 | 08:29 PM
jayonemo's Avatar
Engine: 355
Transmission: 350
Axle/Gears: 342
Didn't work for me. Changed a lot of stuff. No dice
Old May 29, 2014 | 08:42 PM
THCARGUY's Avatar
Car: 1985 & 1991 Trans Ams
Engine: 350 in both
Transmission: Auto in both
Axle/Gears: 3:23 Limited Slip in both
I recently replaced the Driver's side glass so while I was at it I pulled all the tracks and regreased and re-aligned them. They now seem to work like new, faster and quieter. However, I don't know if I want to tackle the Passenger side unless I have to!
Old May 29, 2014 | 08:46 PM
jayonemo's Avatar
Engine: 355
Transmission: 350
Axle/Gears: 342
I did both. De grease and re grease. . Look at the power window replacement. Think it will work
Old May 30, 2014 | 06:26 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I'd like to get faster motors. That'd be badass.
Old May 30, 2014 | 10:52 AM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
It's not the motors that are the problem, it's the wiring. You need to add relays in the system to help it run better.
Here's a diagram, it's for 2nd Gens but it should be similar for 3rd Gens. I haven't done it but I've read only good things about this :
Old Jun 5, 2014 | 09:54 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Where is the relay located on a third gen?
Old Jun 7, 2014 | 06:41 AM
I think there is no relay on 3rd Gens and it wired straight to the fuse box so it should make the mod even simpler.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
stalkier
Aug 13, 2015 12:59 PM
