Air Controller Switch Doesn't Cycle from Vent, Heat, Defrost, etc.
Old Jan 30, 2020 | 08:15 AM
Shinobi'sZ's Avatar
When I slide the top switch from off to any of the positions (with the fan off) I hear what sounds like an air or vacuum leak. When not in AC mode all hot air comes from the defroster vents at the front windshield. It doesn't change in economy when vent is selected. The only time it comes out of the vents facing the cabin is when AC is selected. Temp slider works fine. Thinking maybe the blend door is stuck. Thoughts?
Old Jan 30, 2020 | 10:34 AM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: Air Controller Switch Doesn't Cycle from Vent, Heat, Defrost, etc.
9 times out of 10, it's a bad vacuum selector valve for the HVAC. This part is long discontinued, and AFAIK, only available re-manufactured from Top Down Solutions. Unfortunately this is one of those parts that lasts about 18 months if you're lucky, then goes bad again. Poor design from the factory.
http://www.top-downsolutions.com/ind...search=control
Old Feb 1, 2020 | 10:50 PM
Shinobi'sZ's Avatar
Thanks for pointing me in the right direction. I ended up checking the part and it was leaking. To fix I ran a small bolt and nut through the center to clamp down harder as the plastic retainer was worn. Saw it on a YouTube vid. All works fine now.
Old Feb 2, 2020 | 08:37 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Here is the link to the YouTube vid.
Old Dec 20, 2020 | 03:47 AM
gsmarcano's Avatar
Car: Camaro
Engine: 350-Vortec-carbed
Transmission: 700-r4
Axle/Gears: stockola, right now anyhow
nice, good info,...
Old Dec 20, 2020 | 01:35 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
https://www.youtube.com/watch?v=Mv782CIJDks
Thank you for that information. It is great when people pass along that information to help all of us. Again, thank you!!!
racerx520
Sep 25, 2009 11:37 PM
Subnoizebro
May 11, 2008 07:07 AM
sogabe
Jul 10, 2006 05:29 AM
spedrace35
Dec 3, 2005 04:45 PM
