Dash and gauge cluster removal - strange gauge plugs?
Old Apr 22, 2020 | 08:07 PM
Colt's Avatar
Car: '89 Formula
Engine: 383 Megasquirt
Axle/Gears: 7.625
I'm currently in the process of remove the entire dash from my '89 and I not sure how to unhook these strange plugs on the back of the gauge cluster. Anyone know how to unplug these? I thought I'd ask before I totally destroy something. The strange thing about these is that the barbs on the plugs are going the wrong way, so they were designed to be inserted from the other side. Also, there is no socket on the board, just pins. I tried prying out the lower brown colored one and saw the PCB flexing, which didn't look good...
Old Apr 22, 2020 | 09:28 PM
Drew's Avatar
Re: Dash and gauge cluster removal - strange gauge plugs?
Remove the screws from the front of the cluster, leave the wiring in the dash.
Old Apr 22, 2020 | 11:50 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
The "tabs" your looking at are used to remove the plug from the housing AFTER the dash cluster is removed.
The cluster is removed from the front,...... so you've got to pull off the cluster bezels, remove the screws holding the cluster in place, then pull the cluster off the dash housing from the front. The plugs will remain in place on the dash housing after the cluster is removed.
MC_Camaro92
Aug 26, 2015 11:33 AM
cel19
Oct 8, 2013 08:10 PM
fire350tpi
May 1, 2006 05:40 AM
Bennyb8323
Dec 30, 2002 11:06 AM
