Gauges don't work when Lights are on
Old Jun 9, 2020 | 03:13 PM
dodge2461's Avatar
Hello again. When I turn the lights on my '85 305 Camaro, My tachometer, Oil Pressure Gauge, and Voltmeter(I think that's what it's called) all die and go to zero. My Speedometer, Temp Gauge, and Fuel Gauge all stay on, however. If I turn the dimmer down and make the dash lights almost completely off, all the nonworking gauges will start to work again. Also, my right turn signal indicator will be stuck on, but it does not affect the actual turn signal. That stays on despite how high the dimmer is. Does anyone have an idea what could be causing this? I think it would have to be either the circuit board or the headlight switch, right? Any help is appreciated.
Shepp84Z28
Dec 29, 2014 06:47 AM
Curlyfireman
Mar 19, 2014 07:26 PM
t-topsavage
May 21, 2013 06:57 PM
goodnight144
Nov 2, 2009 10:04 PM
