Question about door handle inner rod
Car: 1989 Firebird Formula 350
Engine: 5.7
Axle/Gears: Stock
Ok. I have been chasing a right side door handle rod for my passenger door for some time. So I have a question. I got one here and I found one on eBay so I have 2 of the for the passenger door. However, I notice this is the exact same bent rod is used on the driver door. On the driver door the bend faces into the car. On the passenger door, the bend faces outside the door. Is this correct? This is the rod that attaches to the outside door handles and connects to the locking mechanism that goes to the door bolt.
So the same rod is used for both driver and passenger is what I am asking. thanks!
Engine: 5.7
Axle/Gears: Stock
Re: Question about door handle inner rod
Does anyone have pics of this bar connectors to confirm? Even better does anyone have a drivers side part available?
Engine: 5.7
Axle/Gears: Stock
So it looks like somehow i have a right handle one in my driver door and it works. I think I have this figured out. thanks for the input 84 1LE
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Glad to help. I never thought the linkage would work on the opposite side.It always looks like it would contact the glass when you roll the window up.
Engine: 5.7
Axle/Gears: Stock
I will update when I get to the doors. I Found a drivers side rod and bought it off eBay. Will take pics etc and upload ASAP. thanks
