Removing Center Console Glove Box Light
Old Nov 30, 2020 | 07:01 PM
brightonrock's Avatar
I can't seem to disconnect the wiring from the center console glove box light. This is the last thing I have to do to get the top plate off. Do I have to cut the wires to get it out? Does not seem to be any connector on it. I grabbed some pictures from this site to show what I'm talking about.
Old Nov 30, 2020 | 07:44 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Re: Removing Center Console Glove Box Light
My 84 TA has a light like this but the setup doesn’t look like that picture. On mine, there is a connector that plugs into the light switch piece. There are little tabs on each side you have to depress to remove the connector. The picture you posted doesn’t seem to have those.
Old Nov 30, 2020 | 09:32 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
The switch your showing must be from a 91-92 Firebird because 82 - 90 used the same switch battmann is showing.you need to follow the wires and look for the plug(connector)i highly doubt that you have to cut wires.
Old Dec 1, 2020 | 10:12 AM
Yes, my car is a 1992 as shown in my first picture. There is no connector as it goes into a wrap just after the light. Looks like the individual terminals were just plugged in to the base. I will take more time an look closer to figure this out.
BR
Old Dec 1, 2020 | 11:02 AM
battmann's Avatar
have you tried unwrapping the wires a little? maybe a previous owner cut and connected the wires without the proper connector. just an assumption. doesn't make sense for GM to not have an easily accessible connector near the switch in case it ever needed replacement.
Old Dec 1, 2020 | 12:21 PM
Here is the actual unit from my car. You can see the wires are connected right to the switch/lamp and the go right to the harness which also runs the SIR cable and the purple wire from the hand brake. The white clip folds down to hold the pins in place.
Old Dec 1, 2020 | 06:52 PM
mantaguy's Avatar
Engine: 5.0 EFI
I'm guessing it goes to the harness under there.91-92 has a harness in there,82-90 didn't have that.
harness no.21 switch is no 9.
jworks
Aug 10, 2019 05:27 PM
chevydrvr
May 21, 2011 11:32 AM
kerryismygirl89
Mar 17, 2009 03:47 PM
aperfectcircle
Interior Parts Wanted
Nov 26, 2006 11:02 PM
CraZ-28
Jun 21, 2003 08:21 PM
