4th gen power seats in a 3rd gen
Old Jan 25, 2021 | 09:58 AM
88BLKTransAmGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 3.77
Anyone that has installed power 4th gen seats in a 3rd gen. What did you have to do with wiring if its already there in the floor? I might have a good deal in some seats coming..
Old Jan 25, 2021 | 10:37 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: 4th gen power seats in a 3rd gen
It should plug right in
Old Jan 26, 2021 | 09:30 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Not necessarily, depends on the year. Mostly the connector. Regardless though, its just pos/neg.
Old Jan 26, 2021 | 10:29 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
^^^ what he said. Cut wires and use whatever set of matching connectors you want (that are suitable).
Old Jan 27, 2021 | 06:54 AM
Engine: 5.7 L98
Axle/Gears: 3.77
Okay. What is the most common way to run a positive/negative to the front passenger seat?
Can I Spice the power from the light in the center console storage compartment?
These are out of a 98 trans am if that makes a difference
Old Jan 27, 2021 | 07:18 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
https://www.thirdgen.org/forums/inte...bird-seat.html
https://www.thirdgen.org/forums/inte...er-lumbar.html
Old Jan 27, 2021 | 08:24 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
The factory power wire goes to a circuit breaker in the fuse block, then to a fuse. Then onto the seat. Neg is straight to ground under the carpet.
I wouldn't use the console light or any low power circuit. You'll just blow the fuse. If you don't already have a OE harness installed. I'd run power straight to battery w/ a 20amp inline fuse, 12g wire should be good enough.
bangthydrum
Dec 26, 2013 05:09 PM
GearDrive63
Apr 8, 2006 01:01 AM
Teebone
May 8, 2004 11:11 PM
IROC_Vert
May 14, 2003 07:40 AM
