plastic for around steering wheel column
Old Feb 4, 2021 | 10:32 PM
Loudaman's Avatar
hi where would I be able to purchase new interior plant fo around the steering column? thanks
Old Feb 9, 2021 | 11:02 AM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: plastic for around steering wheel column
No one is making new steering column plastic trim for these cars. Your only option is going to be used.
Old Feb 9, 2021 | 12:43 PM
kentuckyKITT's Avatar
Car: 2 T-Tops
Engine: 327/305
Transmission: TH350/700R4
Axle/Gears: 3:42/2:73
Found this:
https://shop.advanceautoparts.com/p/...E&gclsrc=aw.ds
Not sure if that's the part you need.
Old Feb 11, 2021 | 12:16 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
You should try www.steeringcolumnservices.com
They have the turn signal/dimmer cover in the later model GM columns.
andy625
Sep 2, 2010 07:12 AM
milleym
Feb 18, 2009 09:19 AM
roughskinjrz
Jun 12, 2007 11:30 AM
killer1958
Jul 7, 2005 03:01 PM
drdave88
May 5, 2003 10:17 PM
