Steering column/wheel question
Old Jul 6, 2005 | 02:16 PM
killer1958's Avatar
Wasn't sure if this was the right place to ask this or not...Just test drove a 89 RS in fair/decent conditon. My question is this: The steering column had kind of a side to side ( R to L ) movement in it. Almost like there was a pin or some kind of support missing/ broken on one side. I mean, when you held the steering wheel, you could move the whole steering wheel and column to one side by probably a couple inches or so. Anyone had this happen? or know what this could be? Car drove fine, but this problem concerned me a bit. Thanks for the help.
Old Jul 6, 2005 | 02:24 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
theres a pin the tilt on the steering rotates on.
if you break the plastic bushing that surrounds that pin, it'll have slop like that...
Old Jul 6, 2005 | 02:33 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
could be the supports under the column just loose. couple of nuts down there...
Old Jul 6, 2005 | 03:21 PM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
my fiero did the same thing and it was 4 torx bolts that were loose inside the column. Tore it apart was a major pita and then replaced the whole column.
Old Jul 6, 2005 | 08:08 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
The few cars in the past we had problems with it was just the bolts had worked loose, only had 1 car in HS that actually had a broken bushing.
Regardless, if your not mechanically inclined and equipped with a little more advanced set of tools (more than a cresent wrench and pliers you might be better of taking it in to a shop if you buy the car. It's not a hard task, just ALOT of things inside there to disasemble and put back into place.
Old Jul 6, 2005 | 08:22 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
did it have about the same amount of up & down play in it? if up & down play is normal, its probably just the nuts under the dash.
if it has about the same amount up & down as side to side, odds are its the 4 torx bolts firebird45331 mentioned, although the bearings could also cause it.
i have never seen 1 that just had side to side play with out almost the same amount of up & down play except when the nuts under the dash were loose.
Old Jul 6, 2005 | 11:27 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
And if you are really curious, Vader posted up directions and pictures on how to fix it... though I can't stand to open those POS up. -shudder-
Old Jul 7, 2005 | 03:33 AM
I'll never tear another steering column apart again.
Old Jul 7, 2005 | 07:42 AM
Car: '91 Z28
Axle/Gears: 323's
is that from a previous experience or you bought the car and said this?
Old Jul 7, 2005 | 11:25 AM
killer1958's Avatar
It's kind of hard to explain...the whole steering column allowed you to move it to the left. If you pushed forward on the left side of the steering wheel...the whole thing moved left and in. Made it very uneasy to drive. I was thinking the steering would fail on the vehicle. I'm not going to purchase the car in any event. It had some other issues. I'm still looking for a decent 3rd gen here in Minnesota. Would love to find one. I've responded to several for sale ads on this site, for some reasonably local sellers, and it seems like no one is checking their ads or messages. I'll keep trying. Thanks for the info.
Old Jul 7, 2005 | 01:38 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Then it's loose inside. It's actually not hard at all to fix if you have the correct tools harbor freight has cheapo pullers and compressors.
Old Jul 7, 2005 | 03:01 PM
need a steering wheel puller, spring compressor, a slide hammer, It was a pain, I thought it was worse than pulling a motor. The bearings fell out and rolled everywhere. just a pita
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
backtothe80s
Sep 5, 2015 12:39 AM
wild1
Aug 27, 2015 09:01 AM
redmaroz
Aug 16, 2015 11:40 PM
