Washer Clips That Attach the Inner Door Panel Top Rails to Door panel?
Old Apr 17, 2021 | 07:09 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
So when taking apart the OLD ones of these from the door panels, there were little round washer clips used to keep this item attached to the door panel... They were hard to get off... when I got to the other door, they were totally gone, someone had rigged it...
I have new inner door rails, but no new round washer clips... anyone know where to get some ???
Thanks,
Raf
Old Apr 21, 2021 | 02:47 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Washer Clips That Attach the Inner Door Panel Top Rails to Door panel?
https://www.clipsandfasteners.com/Th...ex-p/a2896.htm
This is the site you want,my parts book does not list the size you need.I also modified mine wheb
n I replaced them I think I used duck tape IIRC.
Old Apr 21, 2021 | 09:08 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I've got many,..... What is your ZIP code ??
Old Apr 22, 2021 | 06:35 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
I used rivets to attach the door panel to top rail because the plastic "nibs"
were too short to be re-melted over washers holding door panel.
The rivets will be hidden by door top rail when installed so you wont see them.
Old Apr 22, 2021 | 12:56 PM
luvofjah's Avatar
Thanks all for your help, that looks like the right part...
I bought some GM top rails years ago, they are currently in FL with my car and I'm in WA state...
So I'm not sure even how many I need, maybe 5 - 8 per door?
Raf
reefland
Jan 12, 2012 10:09 AM
The Project
May 31, 2011 02:30 PM
Scott Fleming
May 11, 2004 12:39 PM
joezero
Sep 22, 2002 03:26 AM
