Have to hit hatch release multiple times!?!
Old Aug 26, 2021 | 11:16 PM
87BlueCamaro's Avatar
So I just finished installing a new hatch pull down motor and housing. Once I put it back together (mostly) I tested everything to ensure its good. Other then the motor making a rattling noise on the way up and the release button, it seems to be working well.
Before the change I had to hit the release button on my center counsel twice to get it to pop up. Now I have to hit it three times. Big deal? Probably not, its just annoying. Any suggestions on the cause?
Thanks!
Old Aug 27, 2021 | 12:38 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: Have to hit hatch release multiple times!?!
Check the connections at the switch end, try bypassing it and see if you can get a reliable one shot activation. It's possible that the switch itself is faulty, or experiencing a poor connection / compromised wires.
Old Aug 27, 2021 | 05:30 PM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
Mine did that at first when I replaced the plastic gear. A week later it was fine
Old Aug 27, 2021 | 05:34 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
You mean to get it to activate? Or to get the hatch to release?
If it takes several tries to get the solenoid to click / activate, you prolly got dirty contacts somewhere.... if its activating the solenoid but not opening, it could be worn struts not pushing the hatch open
Old Aug 28, 2021 | 08:33 PM
Thanks for the feedback. When press the button I hear click, nothingclick, nothingclick and it pops right up (replaced struts last year).
I have always had to press it twice to get it to go (always heard two clicks). Now its 3.
Not sure if it has anything to do with the replaced pull down motor, but I would doubt it. I did notice a few one of the wires was chewed a bit and am wondering if thats the culprit.
Old Aug 30, 2021 | 12:21 PM
1989karr's Avatar
Engine: 3.4 / 5.0
try hold the button down a little longer? im not sure how it works, but i think if you are too fast it won;t send a long enough signal?
Old Aug 30, 2021 | 09:34 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
My reversing switch went bad so I put a manual switch under the license plate. If I get it down too tight I have to hit the console switch a couple times, or get out and raise the hatch a bit and use the remote. Maybe your hatch is being pulled down too tight?
Old Aug 31, 2021 | 12:01 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
You don't have to guess what is the problem. Take a multimeter and probe a few points in the circuit and see what device isn't passing voltage. It should be extremely easy to troubleshoot since it is so repeatable.
Old Sep 1, 2021 | 09:35 PM
This could be possible. It does seem to seal pretty tight. Im not sure I want to mess with that motor anymore at this point since it seems to be working. I suppose Ill just live with it for now until it breaks again
Old Sep 2, 2021 | 06:00 PM
1989karr's Avatar
Engine: 3.4 / 5.0
For my Firebird I noticed I need to push the butto for about 2 seconds for it to work. It'll catch the first second but if I erelease to ofast it relocks......
mav75
May 27, 2011 02:38 PM
LoganKello
Jan 18, 2011 06:17 PM
87iroczeh
May 12, 2010 10:33 PM
2.8RS
Aug 5, 2008 10:30 AM
rkdz28
Jul 23, 2003 09:42 PM
