Sun visor
Old Apr 30, 2022 | 04:08 PM
BBCSwap's Avatar
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
Sun visor
If you put the sun visor up it drifts to the down position. Any ideas on how to fix this. Wrap the rod with paper, tape of something.
Old Apr 30, 2022 | 05:35 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
Re: Sun visor
There was someone on here who is 3D printing brackets for sun visors. Sorry I can't tell you any more than that. I do know that they were very reasonably priced.
Old Apr 30, 2022 | 06:23 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Sun visor
With mine the rod had worked loose from the rest and spun loose. I took it out, pulled the rod all the way out and epoxied it back in. Unless you just need to tighten the screw that clamps against the rod and keeps that from happening. Flip it down and see if the screw will tighten first. Lots of older GM cars have similar ones if you have a JY handy also.
Old Apr 30, 2022 | 09:18 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Sun visor
https://www.thirdgen.org/forums/inte...un-visors.html
JamesC
Old May 1, 2022 | 06:07 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Sun visor
The plastic sleeve wearing down is usually the issue, second is the loose pin. I've made sleeves from that clear blister packing some products come in. Works very well.
Old May 1, 2022 | 10:45 PM
Drew's Avatar
Re: Sun visor
The mount pin is just splined and pressed into the elbow. The pin can get loose and turn in the elbow. Over-tightening the screw just makes the problem worse since flipping the visor down and up just spins the splines in the elbow. Sometimes you can just tap the pin deeper into the elbow with a hammer.
Old May 12, 2022 | 03:32 PM
BBCSwap's Avatar
Re: Sun visor
My pins were loose. I used lock tite on the pins and then put a wrap of a piece of paper around the pin and no more saggy visors. Thanks guys.
Ben92
Apr 26, 2007 09:37 AM
camarosource
May 27, 2004 01:07 AM
Luke
May 25, 2004 08:58 AM
formula91
Aug 26, 2003 06:21 PM
