Click/tap noise when rolling up window
Old May 31, 2022 | 06:52 PM
atltt's Avatar
Car: 1985 Trans Am
Engine: 305ci
Hey all! I just bought my 1985 Firebird T/A and today it starting making this click sound when it reaches the top of the track and is set with the weather stripping. The sound sounds just like a nickel hitting glass when it reaches the top. This doesn't happen when the door is open and away from the frame. It sounds like it's coming from the A pillar area.
Any idea what it could be? I examined the whole a pillar frame and moved it extremely slowly to try and see if anything was getting loose and knocking into the glass but couldn't see anything. It also doesn't occur if I go as slow as possible with it.
Thanks everyone!
Old Jun 11, 2022 | 07:39 AM
Shadyredeyes's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 350 S/B
Transmission: 700 R4
Axle/Gears: 2.43 Gear Ratio
Re: Click/tap noise when rolling up window
Is it possible the felt window aligners need to be adjusted? Maybe they don't line up well with the plastic catch pieces on the bottom of the window? Just an idea.....
Old Jun 11, 2022 | 08:36 PM
atltt's Avatar
Car: 1985 Trans Am
Engine: 305ci
I will take a quick gander at that, thanks for the suggestion!
Chevy86 IROC-Z
Sep 18, 2010 01:51 PM
kent624
Sep 12, 2010 02:03 PM
phillyterror
Oct 7, 2008 01:10 PM
89GTA2LV
Nov 16, 2004 07:17 PM
92 zzz28
Jan 15, 2003 10:00 PM
