Possible electrical issues.
Old Jan 29, 2023 | 02:26 PM
Slayer91's Avatar
Hello,
I recently purchased my third gen and i have a question when it comes to electrical components. My first is that the cigarette lighter on the dash works but when I plugged in my cell charger into it the dash the charger popped and let the smoke out. Is that just because I need to redo some wiring for the cig lighter or is something more wrong.
Old Jan 29, 2023 | 05:58 PM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
Re: Possible electrical issues.
U have a short somewhere or the cell charger is pulling too many amps.
Old Feb 2, 2023 | 12:35 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Also make sure the lighter socket is clean, and free from anything metal...I had an old dirty penny jammed in the socket of my T/A, which kept killing my battery.
Old Feb 2, 2023 | 07:12 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Under your dash on the drivers side forward and just above the fuse block is an L shaped bracket that holds the dash. Next to it will be a big chunk of harness.
Roll that chunk of harness over, some of the insulation might be rubbed off. I had this issue on my car and a friend had this issue. It’s worth a look.
McCall
Mar 22, 2020 03:59 PM
transamrob86
Mar 26, 2007 10:43 PM
joekickass
Jun 26, 2003 06:37 AM
