Mud bogged
Old Jan 31, 2023 | 02:48 PM
Slayer91's Avatar
Mud bogged
Hello,
My area recieved a lot of rain recently and my camaro bogged down when backing out of a shed. I will need to be towed out or possibe jack up rear end to get myself some grip. I was thinking of getting a 2x6 board and jacking up on the trunk bottom what are your thoughts?
Old Jan 31, 2023 | 03:38 PM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Re: Mud bogged
Man you are stuck. I don't see an easy way to get out of that without it ripping stuff off the bottom of the car.
Old Jan 31, 2023 | 04:34 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Mud bogged
Originally Posted by Slayer91
Hello,
There are times when you can do stuff your self, and there are times when ya just gotta call a pro (In this case, a proper tow truck).......
The money spent on the tow will offset any money you'll spend fixing the damage of trying to extricate that with backyard means.
Old Jan 31, 2023 | 04:55 PM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
Re: Mud bogged
Why did you move it in the first place?
Shaking my head here
Old Jan 31, 2023 | 05:29 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Mud bogged
It's not stuck in that photo, you just don't have enough traction to move because it's a Camaro with smooth tires. Simple assist pull for a truck and a snap strap from the back. I'd wrap the strap criss-cross around both side of center section of axle so it doesn't bend an axle tube. And just walk it out easy, no yanking.
The longer it sits in mud the more likely it will become stuck though as it sinks. And for gosh sakes get it out while the mud is wet.... It'll be entombed if you let it dry.
Old Jan 31, 2023 | 07:36 PM
Aqua Blue RS/SS's Avatar
Re: Mud bogged
Does it freeze there often? I’ve driven more than one stuck truck out of the mud on the freeze…
Old Feb 1, 2023 | 07:10 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: Mud bogged
Wedge some boards under the tires and wait for the ground to dry. The boards will keep it from sinking more and once it is dry you should be able to slowly back it out with some help gently pushing on the B pillars (doors open).
If it is already sunk too far then wait for it to dry, get a shovel, and dig it out.
danderson
Feb 25, 2023 06:42 AM
Evilokc
Dec 3, 2022 12:29 PM
raaneal
Canadian Region
Feb 5, 2017 08:45 AM
KNIGHTE
Jun 30, 2015 12:58 PM
