92 Z28 Carpet Replacement
Car: 91 Z-28 Convertible
Engine: 5.0L
Sorry if this info has already been posted. Perhaps someone can point me to the post or video. I’m looking to replace my carpet and have not been able to find a full video on YouTube that shows how to remove the entire center console. I appreciate the help/info.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: 92 Z28 Carpet Replacement
It is very simple and straight forward. You'll need a small torx bit to remove the top paneling, ash tray, shifter plate, radio plate. You'll then see a few tiny bolts (7mm) around the perimeter of the plastic housing. Once that comes out the console is held in with 4 10mm bolts and a screw on each side that goes under the dash (on each side of the console by the radio) You'll likely need to remove the knee brace under the steering column to have full access to get out the console. The hardest part is removing the window switches.
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
Not a video, but perhaps seeing the parts diagram will give you a visual aid:
https://austinthirdgen.org/1982-92-t...ation-catalog/
Page 1461
Page 1461
