No turn signal and floppy
Old Nov 30, 2023 | 04:57 PM
TheSushiGod's Avatar
Howdy! So, I just purchased a 1984 z28 HO in pretty rough shape. Unfortunately, the turn signal switch is just a floppy useless device and the turn signals do not work. Wipers and high beams do. I'm at a loss at where to begin. I took a couple of pics that are attached. I also noticed in the glove box there is a "cam" gear that i think aids in canceling the turn signal when turning? Is this as simple as removing the housing and replacing the switch as well as getting a new lever? Also, the steering wheel is jiggly a bit. Maybe that's the missing cam doing that? Thank you!
Old Dec 3, 2023 | 01:43 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: No turn signal and floppy
You're probably missing some pieces besides the canceling cam, which probably has nothing to do with the looseness of the wheel. That's sounds more like the notorious four torx bolts that hold the tilt housing to the rest of the column.
Old Dec 4, 2023 | 01:44 PM
Well sir, you were correct. See attached pic as to what I found in the glove box. My only guess is the previous owner was trying to get to the turn signal switch and gave up. What is the notorious Torx bolts issue?
Old Dec 4, 2023 | 06:10 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Now wonder its a little loose. So it may be more than just those 4 torx, like that spring in the background, but here are 2 of the four. They're somewhat buried in the column too.
Jordan iroc z
Jun 2, 2023 10:30 AM
92RS4US
Feb 25, 2012 08:07 AM
truegmman
Mar 22, 2007 06:37 PM
BlueByU
Apr 24, 2006 09:47 PM
SilkWorm
Feb 16, 2002 01:03 AM
