Climate Controls busted
Old Apr 21, 2024 | 06:02 PM
Aingidheachd's Avatar
So, the Climate control in my 92 Camaro does work. The problem is the temp adjuster. It stays on a max heat setting, but when I slide it over to the max cool side, it springs back to the center. Any way to fix this without having to replace the entire control panel?
Old Apr 21, 2024 | 07:23 PM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Re: Climate Controls busted
It's probably the temperature control cable binding up.
Old Apr 21, 2024 | 09:53 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Remove the hush panel on the passenger side dash. The cable connects there to the vent it controls. Might be something binding there as mentioned.
schwoch
Fabrication
Mar 9, 2015 10:43 AM
Trombly
Sep 11, 2012 11:04 PM
trace
Dec 19, 2002 11:52 AM
nblanchard
Jul 10, 2002 08:44 PM
