3rd gen Ignition lock cylinder interchangeability
Old May 5, 2024 | 10:47 PM
Tumbleweed9's Avatar
Okay, I have a 90 camaro RS which of course has VATS equiped. I bought the car with the key broke off in the ignition and I was looking to replace the whole lock cylinder. I’v done ECM delete and engine swap and no longer need vats, engine cranks even with broke part of the key removed. My main concern is if I buy and ignition lock cylinder for a pre 89 camaro (non VATS) will it work with the column in my 90 (w/ VATS)? Only reason I ask is because price on (non VATS) lock cylinder are much cheaper and would be easier to have extra keys made if needed.
Old May 11, 2024 | 12:46 AM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Re: 3rd gen Ignition lock cylinder interchangeability
If you haven't already done it, then yes, a standard ignition cylinder will work, providing VATS has been effectively removed from the equation. I've done it to a VATS car after bypassing VATS.
I didn't compare the two types of ignition cylinders side-by-side, but I was told a standard cylinder is a tad shorter than a VATS cylinder, and that appeared to be true, because the gap between the column cover and ignition cylinder was almost gone, and I wasn't able to push it in far enough to turn it back to ACC mode, but it would push in far enough to turn it forward to start the car.
If I had it to do over again, then I'd get the correct type of ignition cylinder, so that's what I'd recommend now.
Old May 21, 2024 | 09:06 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
similar question, although not VAT's vs No VATs, I know some later model GM cars came with double cut keys in columns similar to third gen columns, has anyone tried installing one in a third gen column? how about door cylinders? I know they offer almost no security benefit over stock, but I need new door cylinders anyways, so swapping to one key might actually be kinda nice.
torqueaddict
Jun 24, 2011 05:15 PM
Eightyninef
Feb 16, 2006 08:34 AM
NHRATA01
Jun 21, 2004 10:08 PM
breathment
Feb 13, 2002 10:44 PM
Pearl89GTA
Aug 7, 2001 10:28 PM
