key stuck - could it be VATS? 89 GTA
Old Jun 22, 2011 | 05:49 PM
torqueaddict's Avatar
Car: 89 GTA
Engine: 5.7 ZZ4 Vortec TPI
Transmission: 7004R
Hi,
Today I found my self unable to turn the ignition from run to off. Key is stuck. I know I have VATS but I wasn't sure if VATS could be doing this or is it just a bad tumbler/lock.
I thought a VATS problem would not prevent the key from turning but would disable the engine (eg. no fuel/spark)
True? If so is a VATS ignition much more $ than a regular one? If so what part would I ask for to get a non vats ignition?
Thanks for any help
-Dan
Old Jun 23, 2011 | 05:00 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: key stuck - could it be VATS? 89 GTA
Correct. I've never seen, read, or heard of VATS mechanically interfering with the key. Sounds like the lock cylinder has malfunctioned.
I don't know the part number but, it's my understanding that the VATS lock cylinder is a lot more expensive because you also have to get a new chipped key.
Hope this helps!
Old Jun 23, 2011 | 05:57 PM
Damon's Avatar
VATS lock cylidners interchange- it's only the resistance of the chip in the key that differs.
Old Jun 23, 2011 | 07:24 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
before you tear into the column, make sure the shifter bowl on the column down near dash moves fully to the park position.
if you do need a new lock cylinder, stay away from the aftermarket VATS lock cylinders. they are only a little cheaper than a Delco lock cylinder and they don't last very long.
you can use a plain non-VATS lock cylinder, but you must do the VATS bypass talked about in the technical section here,
https://www.thirdgen.org/vats
Old Jun 24, 2011 | 02:35 PM
Car: 89 GTA
Transmission: 7004R
I thought so - I will check the park interlock or whatever it is - (I think that's what you were suggesting)
I am running a custom prom I did years ago and I am pretty sure I have VATS disabled.
It seems like going with a standard lock set is simpler since I believe if I get a new VATS lock, I'd need to get a VATS key made that matches the resistance of my current key (not sure how that works but it doesn't sound cheap)
So can I just get an autozone $12 non VATS for my year firebird and expect it to work?
thanks everyone,
-Dan
Old Jun 24, 2011 | 05:15 PM
DENN_SHAH's Avatar
if you have already disabled the VATS system including the starter lockout, then there is no need to get a VATS lock cylinder.
i've installed a fair number of the non VATS after market lock cylinders and though sometimes you may need to wiggle the key a little, they seem to work fine.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
383cam
Sep 9, 2015 06:01 AM
Gunsbee
Sep 7, 2015 07:10 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
