A Pillar Trim Pieces..Possible fix...
Old Jul 26, 2024 | 05:58 PM
zero13's Avatar
Car: 91 Z28
Engine: Enhanced 5.0L
Axle/Gears: 3:42 Posi
So, as expected, pulling off a-pillar trim piece usually the " christmas tree" or similar clips break..No huge deal...unless the plastic they slide into also breaks, then youre screwed....So, I'm in process to figure a remedy...Thinking about JB Welding a bottled beer cap to trim piece in areas that need a clip...Then using tin snips to cut sides of cap into segments...This would allow to fold metal sides and sandwich the clip in, with a tad of slide-ability...Going to attach my ver.1 idea...I'm aware, super rough, but understand concept, and thin profile..The "grab/retain strength is pretty good...
Old Jul 26, 2024 | 06:48 PM
zero13's Avatar
Car: 91 Z28
Re: A Pillar Trim Pieces..Possible fix...
Ok,
ver.2.0...cut square stock( unsure of gauge, but similar to hvac grade...If i can JB weld, This could work..Can paint black, slide-able, removable...
mikeceli
Convertibles
May 1, 2025 07:36 PM
3rdgenkindagal
Oct 4, 2022 12:11 PM
MYZ28NH
Convertibles
Dec 26, 2008 02:03 PM
RedFirebird
Dec 29, 2001 08:35 PM
