VSS Module (Yellow Box)
Car: 1989 GTA - Gunmetal grey
Engine: 5.7 ltr.
Axle/Gears: 3:27 9 Bolt Borg Warner
On a 89 GTA, 5.7...Can someone tell me how the VSS module mounts under the dash ? Buddy had his and his ECM hanging down when replacing the carpet, now he can't figure out how it mounts under the dash. ECM is re-mounted.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: VSS Module (Yellow Box)
Does the ecm mount have a tab on the backside?
Engine: 5.7 ltr.
Engine: 5.7 ltr.
Yes sir. The ECM has this mounting brkt. So it mounts to the tab you have circled. Makes sense now. Thank you so much for your help.
Ob_one
May 17, 2008 10:17 PM
