dash pad screw part number
Old May 11, 2025 | 08:00 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
does anyone have the part number or a good source on the upper dash pad screws 89-up hex head style?
I would like some fresh black oxide ones but they measure a little more than 30mm long and most listings I can find for m4.2 screws in that length are only the older Philips style
Old May 12, 2025 | 08:44 AM
BURD's Avatar
Re: dash pad screw part number
Try motor city fastener.
she even has a vintage book of fasteners.
Old May 12, 2025 | 09:14 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Try searching "gm m4.2-1.41 x 30mm screw" in google and pick the store you like.
Old May 13, 2025 | 07:55 PM
Engine: ls1, LB9
Thanks, I did try that a few different ways before i posted but when i contact the vendors/suppliers they always have too big of a washer. i was able to go through some of the gm numbers and I think I found the correct part numbers (3 different part number changes). I have them on order and they should even be slightly longer than 30mm like the originals
Old May 13, 2025 | 08:20 PM
ratfink6923's Avatar
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
If that doesn't work, let me know. Gm still uses the small head on fender liners and splash shields. I can get you the number.
Old May 13, 2025 | 08:22 PM
midias's Avatar
Awesome glad it worked out
slowTA
Jan 11, 2025 07:58 AM
IanBw
Nov 13, 2014 09:06 PM
Motown
Apr 20, 2012 01:25 AM
beady
May 7, 2005 06:53 PM
92RS shearn
Aftermarket Product Review
Aug 20, 2004 05:28 PM
