Coil spring for front seat belt?
Old Jun 11, 2025 | 04:48 PM
Zerocyde's Avatar
Car: 88 Camaro
Engine: 416 Stroker LS
Transmission: Magnum F
Axle/Gears: 4.11
Is it possible to find the coil for a front seat belt without paying hawks 300 dollars for the entire seat belt? The coils in both of mine slipped out and while I was successful in carefully resetting the drivers side, I screwed up on the passenger side and it sprung out. The local junk yards dont have third gens anymore and I can't find anything online but the entire setup. Is that coil part something that is the same in another car maybe? Or maybe something I could get if I knew the part number?
Old Jun 12, 2025 | 03:28 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Coil spring for front seat belt?
I might be able to come up with some old belts that you can steal the coils from. Are the coils you need for the driver and pass side the same ?? ( Meaning: If I find 2 pass belts,.. does that help ?? )
Do you need the upper and lower assembly ?? For both sides ?? Does the color of the belt matter ??
I'll start digging around to check to see exactly what I've got after I hear back from you.
Old Jun 14, 2025 | 01:30 AM
Zerocyde's Avatar
Car: 88 Camaro
Axle/Gears: 4.11
I appreciate you checking! Color shouldn't matter, and I'm not sure if side matters or not but it is a black passenger side I need. Basically on the side there is a plastic cover that houses the coiled spring. I'm pretty sure I can carefully transfer an unsprung coil from one seatbelt housing to another if I could get my hands on one so condition, color, and hopefully seat side, shouldn't matter.
Old Jun 14, 2025 | 02:06 PM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
Originally Posted by Zerocyde
Is it possible to find the coil for a front seat belt ?
send it to SEATBELTPLANET.COM to be rebuilt.
Old Jun 14, 2025 | 06:03 PM
John in RI's Avatar
I found a red passenger side belt,.... The "inertia" lock seems to work fine on both the upper and lower belt retractor too. ( hold level the belt will pull out,... hold at an angle and the belt can't be pulled out. )
Send me a PM with your ZIP code for a shipping quote and make an offer if you're still lookin'.
Old Jul 23, 2025 | 01:17 PM
350Iroc89's Avatar
Car: 1989 Camaro IROC Z
Transmission: 4L60
Axle/Gears: 2.77 G80 9 bolt
Do you have a seat belt receiver in that color?
Old Jul 24, 2025 | 08:45 AM
John in RI's Avatar
No - Sorry !
Sandy_
May 15, 2024 10:40 AM
HeavyChevy383
Oct 16, 2022 01:23 PM
kitt23
Sep 26, 2015 07:48 PM
1991Formula350
Mar 6, 2004 12:30 AM
