Door Open Chime/Sound Stays on
Car: 1987 Iroc-z
Engine: 5.7L
Hello All
Just wondering if the door open chime/sound is supposed to stay on when the key is out of the ignition and the lights are off?
1987 Iroc-z T-Tops
1987 Iroc-z T-Tops
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Door Open Chime/Sound Stays on
Why disable it though, thats not a fix. Fix it. Check the small black box in the convenience center. If thats not it. My second guess is a ground wire is shorted...somewhere.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
There's some info here that should help: See post 39.
https://www.thirdgen.org/forums/inte...ml#post6065455
