Reproduction Console Top Quality
Old Feb 13, 2026 | 08:22 AM
69-er's Avatar
Has anybody tried the repopped center console tops?
Any comments on fit and finish?
Upper Console
I see Hawk's has a "New GM" upper console. It's described as including the cut outlines for the switches, like the reproductions have. I don't remember my original top having these when I cut the holes in mine.
Is it really GM/NOS?
They also have a repo one for $10 less. It seems like the "GM" one would go for way more.
Old Feb 13, 2026 | 12:20 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Re: Reproduction Console Top Quality
Were There Two Styles My Original Has The One On The Left
Old Feb 13, 2026 | 12:41 PM
Bald_eagle_machine's Avatar
Car: 1988 Trans am GTA
Engine: L98 350 TPI
Axle/Gears: Factory 9 bolt w/disc brakes
I have tons of these OEM in decent used condition. Depending on which style you need. I have ones with no switches, 1 switch, 2 switches, and I think I have one or two with the clock cut out. They will all need new armrests, but I can ship them as just a bare upper console. I also have the carpeted section in black, red, grey and tan. Just dropping this in case you would be interested in used OEM parts.
Old Feb 13, 2026 | 04:32 PM
69-er's Avatar
Wonder why they did that? Was there something installed underneath that area that made it necessary to make room?
I notice that the repro ones are the second design.
Old Feb 13, 2026 | 04:42 PM
69-er's Avatar
I might be interested! I need a three-switch with no clock.
The only reason I am looking at a new one is that mine is decent condition, but has scratches, wear, etc. The textured switch area isn't all that great and I cut out the holes a little big and the switches move around a lot. I though about grafting in a piece. I would also have to sand the scratches and then shoot some satin black. The console is a high-wear area and I'm concerned the paint would start to chip and wear off. I suppose I could use a 2K product. That would be tougher than a rattle can.
Old Feb 13, 2026 | 04:45 PM
69-er's Avatar
Old Feb 14, 2026 | 09:15 AM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
I don't recall ever seeing the one on the right. When was that one used?
Old Feb 15, 2026 | 03:42 PM
gbeaird's Avatar
Car: 1985 Firebird & 1992 Camaro B4C 1LE
Engine: 310 LS1. & 305
Transmission: TH350 & T5
Axle/Gears: 9" 3.73
Does that notch clear the air bag inertia sensor on the 92? I know it's located about there on our B4C.
Old Feb 15, 2026 | 05:36 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
The step or bump (arrow) on the glove box is for the spring on the later "ratchet" style e-brake handles. The spring is all the way to the right and gm could've just added a bump on the corner, but whatever. The early type i believe the spring was mounted differently. So the step is not necessary. That said, i modified the spring mounting on my 89, so i could use my 84 upper console.
Old Feb 15, 2026 | 07:37 PM
Engine: that I like
Well dang. I've had an '89 and a pair of 92's. Shows how often I look in the console, lol.
Old Feb 16, 2026 | 11:51 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I only noticed it was different when I tried to put the console top on. Can't see why GM put the step all the way across. That space is rather limited to start with.
Old Feb 20, 2026 | 11:05 AM
69-er's Avatar
Well, I decided to get an NOS upper console. I didn't want to experiment with the repro units.
Now, I need to cut out the switch holes. I did this on my original years ago but it was a little sloppy in the fit department.
Can anybody provide a photo of the cutouts on a factory console looking straight down?
Old Feb 20, 2026 | 11:25 AM
Engine: L98 350 TPI
Here you go.... couldnt ask for better. Sorry i dropped the ball about sending you my consoles. I have a feeling you are chasing perfection, and my consoles are all used, so they probably wouldn't have fit the bill.
Old Feb 20, 2026 | 11:29 AM
69-er's Avatar
No, don't worry about it all! I would have been the one to contact you if I was going to go with a used unit.
Thank you so much for the measurements!
Old Feb 20, 2026 | 01:35 PM
Engine: that I like
Years ago, consoles like yours were hard to find. So many of them either had holes drilled into them, or the e-brake handle grommet was gone or torn.
Old Feb 20, 2026 | 01:36 PM
Engine: L98 350 TPI
I have roughly 30 of them at the moment. and Even 1 with a working clock!
Old Feb 20, 2026 | 02:10 PM
Engine: that I like
Lol, I think I stopped collecting them when I got to 10 or 15. I have just one with a clock as well.
88BLKTransAmGTA
Sep 1, 2024 04:18 PM
Diabolical
Nov 19, 2001 02:14 AM
