Water leaking into cabin from under dashboard
Old Jun 16, 2026 | 04:38 PM
mariano89's Avatar
Hi. I had my camaro ( 1983 z28 ) for a few months now and recently got the ac fixed, i live in florida and its very hot here!. As soon as i got the ac fixed and started using it, water started accomulating under the passenger carpet. I removed some screws and realized is coming from "the heater core module" ? (correct me if im wrong ) Im stuck now and dont know what would be the next step. I was wondering if anyone can help me, im not much of a car person but trying to learn. I have a haynes repair manual but wasnt much of a help. Attached is a video i uploaded showing the leak. Thank you in advance..
Old Jun 16, 2026 | 06:14 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Re: Water leaking into cabin from under dashboard
There's a drain tube from the EVAP core box to allow the condensation to drain. If it's leaking with the AC running, then that's the source. They may not have hooked it up correctly, or it's blocked with debris
Old Jun 18, 2026 | 06:31 AM
Boostmaster's Avatar
Car: 1987 GTA
Engine: 5.7L tpi
PO- it is likely the drain as EDGE mentioned however, I would simply pull some of these panels and get my eyes on it to be sure. The haynes and chilton manuals are garbage. Get a factory service manual (slightly less garbage) - and do some searching here. Lots of good info, pics, and videos. Every issue that these cars can experience have already been documented somewhere.
19Formula89
Mar 12, 2017 05:24 PM
Chevygurl223
Oct 25, 2013 05:53 PM
Air_Adam
Jun 6, 2005 07:42 PM
my84firebird
Oct 6, 2003 07:46 PM
joemo22
May 13, 2002 03:58 PM
