LSX and LTX Parts Looking to buy or sell LSX or LTX parts? Post it here.
[Wanted] Ls1 swap items
Old Oct 27, 2017 | 01:42 PM
IROC-Turbo's Avatar
Ls1 swap items
It will be an 07 lr4 4l60e from same truck into an 89 that has an older carb wiring harness.
Need f body pan
F body windage tray
F body pickup tube.
Not sure if i need a dipstick or not.
Motor mounts
Fbody manifolds or headers.----Thanks to scooter i have fbody manifolds.
A recommendation of who would be good to get vats and stuff out of the ecm.
Output shaft for a 2wd trans------------Found,Bought a unknown 2wd trans to gut.
Tail housing for a 2wd.Fbody prefered.------------Found.
Trans crossmember.
Thats all i can think of off the top of my head.Will edit as i remember.Or if you have something that should be on this list let me know.
Old Oct 28, 2017 | 07:52 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Ls1 swap items
I have F-body manifolds with Cats attached
I could delete the VATS and other stuff out of the ECM, no tuning, just shutting off the stuff you don't want. Send me a PM if you're interested
Old Oct 28, 2017 | 08:47 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Ls1 swap items
I have a pickup tube and windage tray. Both cleaned and ready to go.
Old Nov 1, 2017 | 05:32 PM
dmtz956's Avatar
Want a title? Post!
Car: 89 z28 camaro
Engine: 4.8l lsx
Transmission: 4l60e
Re: Ls1 swap items
I have a Spohn 4l60e crossmember $90 shipped.
Old Nov 6, 2017 | 10:04 AM
IROC-Turbo's Avatar
Re: Ls1 swap items
Shifty i'll keep you in mind if a can't find a set.
Seems i missed yours dmtz956.Life timing sucks sometimes.Ty though.
Old Nov 8, 2017 | 09:19 PM
Bald_eagle_machine's Avatar
Car: 1988 Trans am GTA
Engine: L98 350 TPI
Axle/Gears: Factory 9 bolt w/disc brakes
Re: Ls1 swap items
Set of UMI adjustable motor mounts, with new bolt kit. $120 brand new, id sell for $90 shipped.
A set of ls1 clamshells, with barely used poly bushings... powder coat is ugly, will need sanding/blasting and fresh paint. Thinking $60 shipped.
Old Nov 25, 2017 | 07:52 AM
IROC-Turbo's Avatar
Re: Ls1 swap items
Are the steel mounts the ones that bolt to the engine?
I'm starting to get confused on them.
And if so,will they work with the stock 3rd gen rubber mounts?As i do not want poly mounts.Just going to be a cruiser.
Old Nov 30, 2017 | 09:06 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: Ls1 swap items
Red steel mounts mount to the K-member. Clamshells mount to the engine.
Opposite of the old SBC that had the cups sit on the rubber mount.
