LSX and LTX Parts Looking to buy or sell LSX or LTX parts? Post it here.
[For Sale] LS3 parts
Old Feb 8, 2021 | 09:37 PM
jrlanham's Avatar
LS3 parts
Im in Olympia wa. Have factory manifolds, hot rod oil pan, and original ls3 oil pan with all parts off crate motor.
Old Feb 9, 2021 | 11:14 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: LS3 parts
Are you bragging or selling? No prices...
Old Feb 9, 2021 | 01:46 PM
Twin_Turbo's Avatar
Re: LS3 parts
How much for the f body pan
Old Feb 9, 2021 | 02:10 PM
jrlanham's Avatar
Re: LS3 parts
Didn’t mean to come off wrong. Just was letting people make offers. I want people to get stuff they need to use instead of having a bunch of paper weights in the garage. I would say $100 for manifolds, $100 for the hot rod oil pan, $150 for factory pan that has parts and filter. Just would like it to get used. Let me know. Sorry at work and can’t respond quickly.
Old Feb 9, 2021 | 06:44 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: LS3 parts
I was joking about the bragging part. Just getting you to write down some prices (forum likes to see prices in all ads).
Old Feb 9, 2021 | 08:37 PM
jrlanham's Avatar
Re: LS3 parts
Good to know. Trying to finish this, then I will do some bragging finally.
Old Feb 13, 2021 | 05:23 PM
jrlanham's Avatar
Re: LS3 parts
if you think you can use the fbody pan make me an offer and let me know. I want to get it to someone who will use it and get it out of the garage.
Old Feb 23, 2021 | 10:01 AM
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
Re: LS3 parts
Nice Camaro - can I have it?
Old Mar 8, 2021 | 04:39 AM
Longshot08's Avatar
Car: 1988 Trans Am GTA
Axle/Gears: Stock
Re: LS3 parts
Nice car!
Old May 2, 2021 | 04:27 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Re: LS3 parts
What exhaust is that?
Old May 19, 2021 | 11:14 AM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Re: LS3 parts
What crate motor did you buy?
Old May 19, 2021 | 08:24 PM
jrlanham's Avatar
Re: LS3 parts
Its a manga flow 67-68 camaro exhaust that is modified. x pipe kit. Had most of the parts we wanted in the kit that my body could modify and was cheaper than buying the pieces.
Old May 19, 2021 | 09:22 PM
jrlanham's Avatar
Re: LS3 parts
It was the LS3 chevrolet from pace performance 525 hp.
Old May 7, 2022 | 09:43 PM
blackgloves's Avatar
Car: 1987 IROC-Z
Engine: 6.2L
Transmission: Stage III T56
Re: LS3 parts
Whats the difference between the two oil pans? I'm in the middle of an LS3 motor swap myself
Old May 7, 2022 | 10:44 PM
jrlanham's Avatar
Re: LS3 parts
ground clearance. The non hot rod oil pan is going to hit the crossmember and not fit a 3rd gen.
Old Aug 11, 2022 | 12:14 PM
regal85lsa's Avatar
Re: LS3 parts
Quick question..... Did you modify the frame to allow mounting the A/C compressor low ?
Old Aug 12, 2022 | 12:49 AM
jrlanham's Avatar
Re: LS3 parts
no it fit had to get the right fitting for the lines but it cleared. I can try to get a pick if you need it.
Old Aug 12, 2022 | 01:52 PM
regal85lsa's Avatar
Re: LS3 parts
If you could get me some pics, that would be very much appreciated.
Old Aug 12, 2022 | 02:30 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: LS3 parts
You wouldn't have a closer up picture of the muffler would you? I am trying to tame down my duals and was thinking of a muffler set-up such as what you have. Sorry for the hijack.
Old Aug 12, 2022 | 10:46 PM
jrlanham's Avatar
Re: LS3 parts
so I had this wrong. It was the power steering we did not have to modify. My buddy did notch the frame for the low mount A/c All get pics
Old Aug 14, 2022 | 04:33 PM
jrlanham's Avatar
Re: LS3 parts
Old Aug 14, 2022 | 04:35 PM
jrlanham's Avatar
Re: LS3 parts
Old Aug 14, 2022 | 04:38 PM
jrlanham's Avatar
Re: LS3 parts
Old Aug 14, 2022 | 05:14 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Re: LS3 parts
Looks so nice under there. What 9" did you go with?
Old Aug 14, 2022 | 07:21 PM
jrlanham's Avatar
Re: LS3 parts
I used a Detroit speed rear end their level 2 package I think it is called and a strange third member.
Old Aug 15, 2022 | 10:39 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Re: LS3 parts
Looks really good. What are the straps that are bolted to the sway bar mounts? I assume you didn't use the top quadralink mounts? I am sorry for bombarding your thread, but your build is super slick and I am intrigued.
EDIT: I am dumb. You are using their full quadralink system. Hence the lack of torque arm.
Old Aug 19, 2022 | 12:47 PM
jrlanham's Avatar
Re: LS3 parts
My buddy that was helping me bought the straps, they are the ones you would use on a 4x4 axle to be heavy duty. We welded in to the frame the boxes by the detroit speed instructions to do the quadra link. He did all the hard work as I am not a good fabricator.
jrlanham
LSX and LTX Parts
Feb 8, 2021 09:27 PM
Lurbie
Nov 29, 2020 04:29 AM
C409
Nov 25, 2020 08:49 PM
Fireslash
LSX and LTX Parts
Mar 11, 2016 04:32 PM
StenInDotte
May 4, 2015 08:43 PM
