ls1 with stock radiator?
Old May 28, 2010 | 03:46 PM
  #51
candy burple rs's Avatar
Car: 87coupe,91RS Camaro's, 00 Suburban
Engine: LSX427HO w/D-1SC and intercooler
Transmission: RPM Tremec T-56 Magnum
Axle/Gears: DTS 12bolt, 3.42
Re: ls1 with stock radiator?
Called Napa and asked to cross ref. the hose and it goes to 80 something to 90 f-250, 350 and super duties too.. so cut cut cut or mod the radiator...
Old May 30, 2010 | 10:09 PM
  #52
Pocket's Avatar
Car: 91 Trans Am
Mine looks completely different too. Almost crumpled up
Regardless, you can clearly see the flared part of the hose in the first pic. This whole section gets cut off. The rad side gets trimmed to fit. Itll likely be about halfway up into the sticker
Old May 31, 2010 | 01:29 AM
  #53
how low is your lower rad hose connection...mine is 1/4 way up due to the BE KOOL rad set up I have. The lenght of the hose would need to be cut down and a slice put in place for it to come up to the rad hose connection...
Old Aug 22, 2010 | 02:12 PM
  #54
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Originally Posted by Mike Massey
stop spending money on hoses and get a ls1 4th gen lower coolant hose instead
well I gave up and did this! I didnt like the size of the ford hose and the other hose I had was sitting too close to the idler arm bolts so I flipped the 4th gen hose like you originally said
see the one end is bigger, I used that end for the 3rdgen radiator since the side tanks are plastic I wanted a perfect fit in case I have to pull it off later I dont want to stress the plastic and the thermostat end although the hose is smaller it slid right on thanks to the coolant left from the old hose. and later on if I need to remove it I will just use a hose removal pick which is the correct way to remove the hoses when stuck
anyway here is the 4th gen lower radiator hose on the stock replacment plastic radiator and stock 4th gen thermostate housing nothing custome here FYI
hope this helps some people out.. it fit like a glove kinda pissed I waisted all that time and money trying other hoses and housings
Old Sep 5, 2010 | 11:55 AM
  #55
five7kid's Avatar
Transmission: 4L80E/4L80E
I used the Gates 7.4l Ford hose on my LS1/T56 swap and got it to work. I tried it again on my LS1/4L60E swap, and for whatever reason could not get it to fit without major kinking.
I went to Advance auto with the 4th gen hose to get a universal. The counter guy took it as a challenge, and after about 20 minutes, came up with a Dayco 71321. This is what it looked like after trimming:
The top left part is larger than the LS1 nipple, so it all has to come off. I trimmed the other end long first (because it's hard to cut something again to make it longer), trial fit it, gave it one more trim and it fit like this:
Doesn't hit anything, doesn't kink. A very slight twist required to get the LS1 nipple and the 3rd gen radiator nipples connected. I can't vouch for the application, but another member said it is for 1987-2001 Jeep Cherokee with a 4.0 L6.
Old Sep 8, 2010 | 07:41 AM
  #56
bigals87z28's Avatar
Car: Check The Sig
It does cross over to a jeep cherokee and i have 3 in stock w00t! Thank you guys who have pionered and blazed a path for many of us to follow!
Old Sep 8, 2010 | 08:23 AM
  #57
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
i've added this part number to my list, seeing as advance is right down to road from me and i'm still hose-less at the moment
oh, and don't forget the "D" before that part number; dayco labels their hoses A-E, might cause an issue when trying to look up the part
Old Sep 8, 2010 | 09:59 AM
  #58
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
good info. Added to my ever-expanding spreadsheet of knowledge.
Old Sep 8, 2010 | 07:20 PM
  #59
Pocket's Avatar
Car: 91 Trans Am
I may have to switch from the ford unit to this. The intercooler pushed my rad back and the hose is pretty tight in there. This one looks like a trim would allow for some fitment variations
Old Mar 2, 2025 | 06:11 PM
  #60
Sodium's Avatar
Thank you to everyone. Almost 15 years later this discussion is still useful. Really helped alot
Old May 15, 2025 | 09:06 AM
  #61
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Adding this to anyone who needs it later. Lower coolant hose Gates 21615 1.75"/1.50" and every cross reference for that same hose
https://www.finditparts.com/products...jViQXLA0QOFFSS
1992 Trans Am
May 10, 2023 07:19 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
sreZ28
Aug 14, 2015 07:48 PM
