lt1 issues spark fuel????
Old May 13, 2005 | 06:48 PM
ssean92's Avatar
Car: sold
ok i have the car running but it runs like crap. it sounds like it has a bad miss. i changed out the optispark cap and rotor and still the same. i pulled off the injector harness one by one to see if the idle changed and it didnt when i pulled off 5, 7, 2.4 this sounds like it is in some kind of closed loop. I do have a engine light but everything that people have told me to do to get the codes out didnt work. I know that it has to be something simple. how can i ck to see if i am getting spark to the cylinders that seem to be dead, with out shocking the crap out of myself. and does anyone have any idea what it might be. Oh yeah this seemed strange to me also when i had the car at top dead center and the cam dowl pin at 9 oclock position the rotor was pointiing towards #2 cylinder on the cap this just didnt seem right i looked at the manual and buy it the only way it will go on it one way and i guess it this was wrong it wouldnt even start. this lt1 stuff is new to me so any help will be appriciated. I cked fuel pressure and it is at 45 with vaccum off, 40 with it hooked up at idle.
Old May 13, 2005 | 09:16 PM
ssean92's Avatar
Car: sold
ttt
Old May 13, 2005 | 09:26 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
What I found out on mine was it was firing on only 4 cylinders because I only had one set of injectors hooked up. In the C100 connector in the LT1 harness for the 95 engine I have, there is one pink wire for 4 injectors which are cylinders 2, 3, 5, and 8 and one for ignition. In the other connector where the C100 is (the one with the tan weatherseal) there is a pink wire there as well for the other 4 injectors for cylinders 1, 4, 6, and 7. After I got power to those, car ran like a champ.
Old May 13, 2005 | 09:30 PM
ssean92's Avatar
Car: sold
my harness was sent off to 350lt1 and i only have the one pink wire?????????????
Old May 13, 2005 | 10:14 PM
ligtag's Avatar
Car: 79 Camaro
Engine: 5.7 LT1
Hi ssean92. Check out www.hotrodlane.cc its street and performance. I got a dvd about the swap from them before I started mine and they shop harness installation ( thiers of course) and some other good stuff. They also say that inorder for you to run your 700r4 you need a 93 computer and they do exchanges on them. You might even call them they have been great on the phone for me.
Good luck
Old May 13, 2005 | 11:31 PM
ssean92's Avatar
Car: sold
thanks i will have to do that
Old May 14, 2005 | 03:27 PM
ssean92's Avatar
Car: sold
i have spark to all cylinders i have no fuel to 5,7,2,4 it cant be what Klortho said do to the injectors are from both the banks. does anyone have any ideas what could cause this. i ohmned all the injectors and they are all 14.2 so i figure that the injectors are good. anyone know what my next step should be?
Old May 14, 2005 | 05:40 PM
Klortho's Avatar
Car: 1987 GTA
When the harness was re-done, was it unwrapped and then put back together? It is possible that the injector wires for those cylinders have been swapped around with 5 plugged into 7, 2 into 4 and vice versa, I'll see if I can get you some pictures of my injector harness (since I had to pull the motor back out) and see if that will help you out any.
Old May 15, 2005 | 06:47 AM
ssean92's Avatar
Car: sold
cked all the injector harness and they are all pulsing. i quess i need to find out what the engine light is. i have fuel and spark.
Old May 15, 2005 | 08:55 AM
Klortho's Avatar
Car: 1987 GTA
I would flip flop the #5 and #7 then the #2 and #4 injector wires around first, it almost seems like they are swapped which isn't letting the fuel get into the cylinder before it has to fire.
Old May 17, 2005 | 06:30 PM
ssean92's Avatar
Car: sold
just an update i am getting a new optispark to see if that helps, i had spark and fuel so i quess that is the next plan. wish me luck. lol
midge54
Dec 27, 2019 04:14 PM
mdtoren
Aug 23, 2015 12:52 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
mdtoren
Aug 16, 2015 05:45 PM
djmarch
Aug 9, 2015 05:27 PM
