#8 plug wire hitting the heater box
Old Jun 21, 2005 | 11:27 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
I remember hearing some guys complain about this along time ago. What do you do to take care of it? After installing my motor, I've noticed that the #8 plug wire boot at the coil pack is hitting the heater box. Pics/help greatly appreciated!
thanks!
-Jeremy
Old Jun 21, 2005 | 11:37 PM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
ive heard of using truck packs as they have more clearance.. or you can try takin the coil pack off and movin that last one around in the bracket or something? :|
Old Jun 21, 2005 | 11:40 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Yeah I was going to try and move it around or even make a different mounting bracket but that's alot of work if there is a simple fix. You not running a heater/ac box in yours??
Old Jun 22, 2005 | 12:03 AM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Axle/Gears: 4.11s
theres an expensive fix with the relocated packs
i cant find a pic close up of anyone running the full box
tom's car had the box and everything in there.. maybe he will chime in
http://www.hawksthirdgenparts.com/89_rs_convertible
speartech's got the truck pack on there
http://www.speartech.com/coproj-1991ls1.html
just watched 5.0camaros vid again and hes got the ls1 packs and a full box so maybe he's got the solution
my solution was to remove everything for max clearance until i can get a proper box
Old Jun 22, 2005 | 12:53 AM
5.0Camaro's Avatar
Car: 1991 camaro Z28
mine cleared just fine, but i'm running a hawks tubuler k-member, so i really dont know how much different it would be with the stock one.
Justin
Old Jun 22, 2005 | 03:34 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I just ran truck coils. I swapped over the hole right bank bracket.
Old Jun 22, 2005 | 07:42 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
How much are the truck coils? Where you'd guys get them??
Old Jun 22, 2005 | 08:30 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
mines really close, but it clears.... no idea why mine clears when others dont.
i do have a steel 83 camaro heater only box on though.....
Old Jul 3, 2005 | 01:12 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
That's probably why then.
*When you gonna help me figure out my wiring????
Anyone else?? I think speartech or someone "modified" their AC/heater box for clearance. Not sure what I'm going to do. I've been waiting on a call back from Bruce Hawkins for some swap details.
Old Jul 3, 2005 | 08:01 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
as soon as you tell me what you need help with...
lol..
soon as i get back to work (tuseday) i'll start making a chart or somthing so its easier to visualize the wire connections...
Old Jul 3, 2005 | 08:07 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
PM sent back, thanks bro!
Old Jul 9, 2005 | 07:54 AM
89rsragtop's Avatar
Car: blue
Transmission: 6 speed
Axle/Gears: 3.73 posi
Sorry guys I just saw this. What Bruce did for me was to trim back the edge of the box seam. He then resealed the box . It is real close between box and coil but they don't touch I will get a picture next week. Camera is on vacation with the wife.
Old Jul 10, 2005 | 08:55 AM
thebigwelsh's Avatar
Car: 88 firebird under construction
Engine: 350 with trick flow everything
Transmission: th350
If the tubular member clears that means it must be a small drop crossmember. So if ya shim your stocker 1/4-1/2 it should be the same.
Old Jul 21, 2005 | 03:32 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Shim my stock k-member??
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
