Wierd LT1 bracket request!
Old Jul 19, 2005 | 09:06 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
I am switching my LT1 over to vette brackets to restore A/C and I ran into a snag. I have everything I need except two things: the vette power steering pump pulley and the top to the A/C compressor. The pulley is no problem but the compressor part is. I bought a compressor through the parts store I work at and it did not come with the top plate that fastens to the A/C lines. I checked GM and they said I would have to by a new compressor. I am not buying another compressor! Local salvage yards treat me like I am crazy when I ask about a used compressor or any other parts for a vette. Does anyone know where I can obtain this part or where I might start looking. Summer is here and I sure would like to have A/C.
Old Jul 20, 2005 | 08:03 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
You can have AC with the F-body brackets, you can get this adapter here http://www.acsource.com/index.asp?Pa...ROD&ProdID=377 or one from Carquest if you have already modified the k-member on the passenger side for the compressor to clear.
Old Jul 20, 2005 | 09:50 AM
Firebat's Avatar
edit: deleted post, i was off the subject, my bad
Old Jul 20, 2005 | 06:00 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
I am aware of that compressor block. I believe I was the first to post about it. I notched my crossmember to clear the compressor, but I did not like the way everything fit. I did not like how close the lines would have been to my headers. This is why I am changing brackets. The vette brackets also simplify power steering lines. I have already purchased the vette accessories and I think I wil be happier with them.
Old Jul 21, 2005 | 10:21 AM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
I would really like to find the top plate from a used compressor and put it on mine. I will have most of the F-body brackets availible if anyone is interested. I have checked with a couple vette salvage places online and had no luck.
Old Jul 21, 2005 | 03:20 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
Thanks for that link and picture! That's exactly what I've been looking for, for my LS1 swap! I'm using the stock LS1 AC compressor with a notched k-member and 3rd gen or 4th gen AC lines won't work!
Old Jul 21, 2005 | 03:24 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Anyone have the Carquest part #???
Old Jul 21, 2005 | 03:33 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Hey bingo, where did you get your corvette brackets from? I want to change my postion of compressor too.
Old Jul 21, 2005 | 04:11 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
I ordered the main bracket from GM( hasn't come in yet ),the tensioner and compressor are from Autozone, the idler pulley and balancer are from NAPA, and the bolts are from a local GM dealership. I am going to use my alternator and power steering pump from the F body setup. I am going to swap everything as soon as the bracket comes in.
Old Jul 21, 2005 | 04:14 PM
Firebat's Avatar
just wondering. This is the a/c alternative i went with. Would this have been cheaper. its an a/c relocation kit. It comes with a/c delete pulley, belt, a/c relocation bracket.
http://www.bowersrodshop.com/info_pulley.htm
Old Jul 21, 2005 | 04:22 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
I saw that and posted it months ago. I thought about it, but I decided on the vette accessories after seeing pics of a few cars. I have about $500 in my vette stuff. I also had the F body A/C compressor lock up shortly after getting my engine.
Old Jul 21, 2005 | 07:16 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
That bracket looks good firebat.... I think i would get that on. the compressor on the LT
Old Jul 21, 2005 | 07:19 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
discard that last post boss... anyways, did the LT1 come with
R-12 compressors or the R-134A? and are the camaros and corvetts the same compressor wise? and will i be able to use my stock set up beside the compressor? sorry bingo i dont mean to steal your tread
Old Jul 21, 2005 | 09:32 PM
Firebat's Avatar
it uses the R-134A F-body LT1 compressor. Dont know if camaro's and vette's are the same. I'd say contact your local GM dealer.
I was planning on reuseing all the stock 3rd gen a/c except the compressor. Havent completely finished it yet. My old A/C was in the exact same location and i hooked up the lines to the LT1 compressor. But, i dont know if is going to leak or not. I live in one state and my project car lives in another. I dont get to work on it that often.
Contact Bowers for your questions on the kit- http://www.bowersrodshop.com/contact.htm
88SS6SPEED
Nov 11, 2015 07:05 AM
mud runner
Nov 2, 2015 07:30 PM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
andy74
Sep 3, 2015 08:41 AM
