after the swap power?
Old Jul 26, 2005 | 02:41 AM
  #51
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Transmission: 4L60E SS3600
Originally posted by MrDude_1
also:
the hotcam SUCKS!
I agree. Go big or go home!! hehe.
Old Jul 26, 2005 | 08:07 AM
  #52
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
its not even that.
the lobe profile is so timid that it gives far less power gains then a identical duration, identical LSA, identical lift aftermarket cam.
it has a meaner idle to it, but thats about it. you toss that cam in a LS1, and you wont see anywhere near the gains that even a mild 218 comp cam grind will give you... the LS1 has these nice huge cam lobe base circles, you can make some really aggressive cam profiles and get alot of power out of a tiny cam... the valvetrain problems were worked out from the inital design.. toss some beehive 918s in, and you can run a XR lobe 224 cam for over 90,000 miles...
the GM hotcam for the LS1 is just a poor choice.. i mean, its better then stock, but you can get a cleaner idle, and more power from other cams... for a thirdgen comparison, it would be like recommending a L98 cam for a L03... sure its better.... but getting a different cam would work better in every way.
Old Jul 26, 2005 | 09:33 AM
  #53
Kandied91z's Avatar
Originally posted by GTA91
True... I did get off topic... sorry... but he is right, a stock LS1/M6 or stock LS1/A4 setup in a 3rd gen is going to dyno almost exactly what it would in a 4th gen. What's the point then, that isn't any fun
Mr. Dude- Why you say the hotcam sucks?
base numbers, reliability and they do dyno differently, track numbers would be more important though in this instance. either way it's a question all the same to be answered.
Old Jul 26, 2005 | 10:56 AM
  #54
MrDude_1's Avatar
Car: 91 Camaro Vert
ok i have to ask.
how do they dyno differently?
as far as track numbers, i only have 1/8th mile slips so far.
Code:
Date		Time	Track		Lane	Reaction	60'	ET	MPH	Desc of run								Win	Temp			Humidity	Weather/ track conditions			Race Weight
7/6/2005	20:11	Dorchester	Right	0.484		2.107	8.643	89.355	still spinning between shifts and on launch, but best of night.		Win	86°F			77%	Guess from weather online. Not measured at track	3660
7/6/2005	20:17	Dorchester	Left	0.202		2.084	9.063	69.275	Missed third.. Managed to stick it in just before the line		Win	86°F			77%	Guess from weather online. Not measured at track	3660
7/6/2005	20:25	Dorchester	Left	0.202		2.160	9.045	79.100	no traction								Win	86°F			77%	Guess from weather online. Not measured at track	3660
7/6/2005	20:48	Dorchester	Left	0.241		2.081	8.743	85.361	no traction								Win	85°F			77%	Guess from weather online. Not measured at track	3660
7/6/2005	20:56	Dorchester	Left	0.429		2.133	8.834	85.845	no traction								Win	83°F			77%	Guess from weather online. Not measured at track	3660
7/6/2005	21:09	Dorchester	Left	0.531		2.170	8.831	86.294	no traction								Win	83°F			77%	Guess from weather online. Not measured at track	3660
7/8/2005	8:25	Lowcountry	Left	0.859		2.046	8.660	84.630	weather SUCKS. Less spin with reloc brackets. Still spinning.		Win	136 corrected		60%	Baro 32.21   hot, humid and sticky weather.. 		3660
7/8/2005		Lowcountry	Right	0.471		2.038	9.024	76.620	wouldn’t shift right..  Hyd clutch problems.				Lose	147 corrected		59%	Baro 32.21   hot, humid and sticky weather.. 		3660
7/8/2005	8:03	Lowcountry	Left	0.572		2.032	8.761	83.710										win	140 corrected		60%	Baro 32.21   hot, humid and sticky weather.. 		3660
7/8/2005	8:48	Lowcountry	Right	0.703		2.046	8.624	84.790										win	141 corrected		59%	Baro 32.21   hot, humid and sticky weather.. 		3660
7/8/2005		Lowcountry	Right	0.576		2.141	9.163	77.120	wouldn’t go into 3rd.. Had to retry					lose	149 corrected		58%	Baro 32.21   hot, humid and sticky weather.. 		3660
i also keep track of my MPG, oil changes, misc maintenance, ect....
btw, in my defence for the slips above... the clutch hydraulics suck. it'll improve with the mcleod clutch master... oh, and traction.. lol traction SUCKED on all of thoes runs.
edit: fixed spacing. didnt notice it was off yesterday
Old Jul 26, 2005 | 11:01 AM
  #55
MrDude_1's Avatar
Car: 91 Camaro Vert
thoes all over the place ETs to be exactly what you should expect with a stock LS1 in a thirdgen with street tires and zero traction mods.... lol
the Dorchester runs on the 6th had bridgestone potenzas... on the lowcountry dragway runs on the 8th, i put KDWs on.... i had gotten a nail in one of the potenzas, and i couldnt plug it, so i just swapped both tires to the old KDWs
Old Jul 26, 2005 | 12:10 PM
  #56
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
ok i have to ask.
Yeah, I don't understand that at all. Same motor, trans, driveshaft, and rearend. I don't see how the dyno #'s could vary at all. Maybe 5% or less.... nothing at all though.
Mr. Dude- Nice times, that thing completely stock? 89MPH in the 1/8th?
Old Jul 26, 2005 | 12:15 PM
  #57
MrDude_1's Avatar
Car: 91 Camaro Vert
yea, i flipped when i saw that too. doesnt seem possible... but whenever i hook, it just keeps pulling... if i stick some tires under her, it should do it consistantly... i know i MPH a bit higher because i spin, but im still thinking 86 or 87 MPH.... not bad for a stock motor.. lol
Old Jul 26, 2005 | 03:27 PM
  #58
MrDude_1's Avatar
Car: 91 Camaro Vert
since i had someone PM me, and im sure you'll ask anyway, heres my MPG and stuffs for this month:
Code:
Fill on Date	Gallons	Price per gal	Miles Driven	Driving desc								Gas station						MPG		Fuel Total	Misc
7/3/2005	13.368	2.219		241.55		just driving								Sunoco 2675 -- across from apartment			18.0692699	$29.66		Premium gas
7/6/2005	14.146	2.269		236.7		commuting and mostly hwy with last 1/4 tank at dorchester		Sunoco 2675 -- across from apartment			16.73264527	$32.10		Premium gas
7/11/2005	13.938	2.339		252.6		cruising around mostly.. 50/50 hwy city, last 1/4 spent at cooper	Sunoco 2675 -- across from apartment			18.12311666	$32.60		Premium gas
7/15/2005	13.633	2.339		235.4		just driving								Hess 5777 - dorchester, near suzuki dealer		17.26692584	$31.89		Premium gas
7/17/2005	13.632	2.339		267.4		Just driving								Circle K 5123 - corner of montague and dorchester	19.61561033	$31.89		Premium gas
7/22/2005	14.229	2.339		250.6		just driving								Sunoco 2675 -- across from apartment			17.61191932	$33.28		Premium gas
Old Jul 27, 2005 | 09:25 AM
  #59
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Mr. Dude, Your time slips pretty much confirm why I have so much fun with LS1's at the 1/8 mile tracks. Most of the guys there are pretty ticked when a 84 model land yaht beats them to the 1/8. I run pretty consistant 8.80's but at only 78 mph. What those guys don't know is how bad the LS1's pull on me at the 1/4 mile tracks. It's somthin crazy how fast they come by you just past the 1/8 th. I can't wait to get a LS1 in my car, if I can keep it hooking like it does and just add the top end pull I'll have a pretty quick car.
Old Jul 27, 2005 | 09:52 AM
  #60
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Code:
Geeez, what are you doing to get such crappy gas milage??
The first tank I put in the LT1 I drove the fool out of it and still got 26MPG
I have a buddy with a 98 TA that's putting 430 at the wheels down (no juice) with 4.10's in a 12 bolt that gets 27 on the interstate.
Old Jul 27, 2005 | 09:58 AM
  #61
MrDude_1's Avatar
Car: 91 Camaro Vert
lol.
first couple tanks when i was babying it (new install, didnt want to break it yet.) i got high 20s... one hwy trip netted me 30!! i freaked when i saw that.. lol
for the way im driving it, and the amount of traffic i go thru everyday, im pretty happy with it. im sure MPG will increase some after i change the plugs, and uncork the exhaust some... but i dont expect it much higher then low 20s/ high teens no matter what.
on roadtrips though, the gas milage goes way up.
gta90
Sep 15, 2015 04:00 PM
E Rod
Aug 28, 2015 05:17 AM
InfinityShade
Aug 22, 2015 08:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
sreZ28
Aug 14, 2015 07:48 PM
