ecm orange constant
Old Aug 4, 2005 | 01:37 AM
Kandied91z's Avatar
ecm orange constant
what amp fuse should the orange constant off the ecm be or can you tie it in direct to the battery?
Old Aug 4, 2005 | 05:15 PM
CamaroCain's Avatar
Car: 88 Camaro
The factory uses a 10amp fuse from the battery to the pcm on the orange constant wires and a 15 amp fuse on the ignition voltage to the pcm.
Use the fuses, they are cheap protection incase of a short.
Old Aug 5, 2005 | 01:00 AM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Transmission: 4L60E SS3600
What he said. ^^^
I wired in an in line fuse holder for the 15 amp fuse off the orange wire to the PCM just in case. You can get a single fuse in-line fuse thing at Autozone or store like that.
Old Aug 5, 2005 | 01:09 AM
Kandied91z's Avatar
thanks.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
